convertible suggestions
Discussion in 'What Tablet PC Should I Buy?' started by stankanovic, Apr 19, 2015.
  1. stankanovic
    stankanovic Pen Pal - Newbie
    So what i would need is a device with pretty decent power, good for drawing, ideally with a decent graphics card however this is not a huge priority, and a nice keyboard. 2 in one would be great as i travel a lot and less is better. would be nice if i had access to RAM and HD as i could upgrade the device myself. Ideally looking for a device to keep for 3-4 years so something that could stand the test of time would be nice. Will be starting univeristy soon so would be nice if for notetaking too.
    Been doing a bit of research and the Surface pro 3 seems like a decent option. But the keyboard looks a bit disappointing and it seems to be a Tablet first and laptop second. I would like to have a more powerful device that functions as a Laptop primarily and as a tablet mainly for drawing pruposes. Have been looking at Lenovo thinkpad yoga 12,14 and 15. I like the more solid build and more powerful capabilities in terms of graphics. the main question would be regarding drawing capabilities on them. are they actually any good for that? Also are there some other options i'm overlooking that would be worth considering?
    General Questions.
    1. What is your budget?
    Ideally would be 1000$ (new zealand) but would be willing to go up to 1500$ (new zealand)
    Either would be fine
    a larger screen would be nicer 10-15inches
    New Zealand, however in a few months time I'll be in SE Asia and i have the option to purchase from Europe too.
    Currently using a Lenovo e530 which has been pretty good. i like the fact that its a sturdy build that can take a bit of rough treatment.
    Not particularly fussed. would be nice to have at lest 4-5 hours though
    Would be my main device and possibly only device so would be nice if it had the power to do a bit of everything. definitely notetaking, videos, good drawing capabilities (not necessarily professional level), basic autocad and would be nice to be able to play some games on it too.
    Would be happy with windows but open to options
    basic autocad, photoshop, illlustrator...
    maybe online game of fifa, football manager, would be nice to try out some of the newer games too like batman arkham city and the like.
    not really
    Screen Specifics
    Anything suitable for drawing
    Sometimes
    Yes! with pressure sensitivity, wacom or n-trig as long as it does the job
    Component Specifics
    I guess 8GB ram would do it and 128, 256 SSD would be ideal. can do the necessary upgrades myself to save money
    Full sized USB would be good
  2. stankanovic
    did a bit more research and it seems like the thinkpad helix 2 is quite a nice option. Otherwise might consider getting a 'standalone' tablet for drawing sketching now and getting a more powerful laptop later on in the year. Any suggestions/quick comparisons between the samsung galaxy note tablets and the toshiba encore 2?
Similar Threads - convertible suggestions
  1. ibmthink
    1,964
