Convertible/2-in-1 for Notes and GIS
Discussion in 'What Tablet PC Should I Buy?' started by Mountain343, Feb 23, 2015.
  1. Mountain343
    Mountain343 Pen Pal - Newbie
    General Questions.
    1. What is your budget?
    Under 1200 preferably, but willing to go above if necessary.
    No.
    iPad is definitely out, but the other two might be ok.
    • Above 13-inches
    13-15. I currently have an HP TX2500z with a 12.1 and it's just too small
    United States
    With the latest brouhaha with Lenovo, I'm very reluctant to purchase from them.
    The longer the better! I have 3 to 5 hour classes, and some days back to back classes where I just barely have time to swap a battery and no place to plug in.
    Primary function will be for taking notes in OneNote, but I also need a screen that is good for reading PDF's and E-textbooks.
    Secondary function is for QGIS and ArcGIS mapping as I am a Geography/Environmental Studies Major.
    Right now I have the TX2500x and it works pretty good, except that it's heavy, has low battery life (2-3 hrs on best setting) and it's really poor for reading with light fall off at the edges and weird issues in portrait mode.
    It must have an active digitizer as good as/or better than my current TX2500. I spend a lot of time drawing diagrams, working in Q and Arc, and highlighting and annotating pdfs.
    Has to be Windows so it can run Q and Arc.
    QGIS, ArcGIS, OneNote
    no
    No
    Screen Specifics
    As high as I can get. My current laptop has 1280x800 and it's fine
    Rarely if ever. Not an issue for the most part.
    Yes, active digitizer is a must. I've never used N-Trig, but if it'll work with Arc and Q that's fine. I'm not an artist, I don't need to draw super fine lines and detail and stuff. I just need to make good diagrams, do math, and draw polygons and click along a path.
    Component Specifics
    Hard drive should be 250+ I'm thinking. Memory would be best to be 8gb. I have 3 now and it's dragging hard.
    I'm thinking full size USB is a must, I guess vga is no longer a thing, so hdmi would be nice to use a second monitor in the computer labs which have vga inputs. SD would be nice as well.
    Misc
    I'd love a detachable screen but doesn't have to be. Must have the ability to use a 2nd battery that is easily swapped for long days.
    I won't lie, I love my Tx2500. It's served me very well for 6 years and it's still doing really well. I love the keyboard, I love the wacom digitizer, I actually use the remote control a lot and the dual headphone ports comes in handy when watching class videos with others. It's not too big like a lot of the 15 and 17 inches seemed to be, and it's not too small like the Surface Pro's were, though the new one I believe is the same size as my TX is now. 13 seems to be the size I really need though, especially for pdf's.
    Also I don't know if Core M will run Q and ArcGIS, i'm mostly focused on i3's and preferably an i5.
    The most important thing is that I'm not in a hurry to rush out and buy anything, but if there's something out there that fits what I need, I'm all ears!
    Ones I've looked at are
    Fujitsu Q775/T935
    Dell Inspiron and Latitude 13 7000 (is this an active digitizer???)
    Acer R13
    HP Envy x2 13 (can't sit it on my lap and type in classes without a table)
    Thanks for any help or thoughts!
  2. Mountain343
    Just an update since no one replied. my TX finally died on me and I ended up buying the HP Spectre x360. While it doesn't have the removeable battery, it has so far met all of my needs!
    I also picked up the dell pen for it, and it's been great for digitizing maps and quick notes.
    And since the store had a sale, I also got the ASUS T100 for use as a second screen for under 200 bucks. The two together with my kindle make for a great multi screen setup in the library and meet all of my needs.
    Bronsky likes this.
  3. Bronsky
    8,593
    5,898
    Sorry we missed your post but you seem to have done okay. I like the Spectre a lot better than any of the Inspiron line, the R13 or the Envy X2 13.
  4. cliffr39
    cliffr39 Pen Pal - Newbie
    51
    23
    Really... Better than the envy x2 13? I was actually checking that out.
    Glad you found a great combination of devices to suit your needs
  5. Bronsky
    8,593
    5,898
    My beef with the Envy 13 x2 is the weight, aspect ratio and the lack of direct connection with the keyboard. Without the keyboard it is nearly a pound heavier than my old 13.3" Thinkpad X301.:eek: The 16:9, well, its 16:9. I just don't think the Envy makes a great tablet. Plus, I would prefer a direct connection over a BT keyboard. The keyboard is decent but the Spectre is far better IMO. The unit is .6 lb lighter with keyboard attached. The only thing I really hate about the Spectre is its trackpad. The damn thing is just too big.
