compatible stylus for 310 series
Discussion in 'Acer (Gateway)' started by impaler, Jul 6, 2006.
  1. impaler
    impaler Pen Pal - Newbie
    hello fellow tableters,
    I just got new acer C312xmi tablet and was wondering if anyone else has used different stylus pens on the screen, like the ones with the other wacom tablet products like graphire and intuos. I have used these other stylus pens before and they are so much more comfortable.
    I noticed that the tablet technology has 256 levels of pressure sensitivity and the regular non monitor tablets have twice as much. This i would assume that there would be compatibility issues..??
    Anyways anyone out there tried to use a different stylus on their tablet pc???
    Chris..:confused:
  2. P8RSON
    5,189
    Chris,
    Any of the replacement pens from Wacom listed here should be fine to work instead of your default stylus.
  3. Gautam
    Gautam Moderator
    484
    take the info you got from P8RSON and go to ebay and you can find a cheap price on a replacement stylus.
  4. impaler
    thankyou P8RSON, those pens just seem so uncomfortable for long perids of drawing compared to the other Stylus on regular tablets.
    Wacom Penabled® technology I hope that meaas that all stylus are compatible:confused:
