Coming from a pavilion x2 12 wich is dying
Discussion in 'What Tablet PC Should I Buy?' started by nyrull, Jan 26, 2019.
  1. nyrull
    nyrull Pen Pal - Newbie
    General Questions.
    1. What is your budget?
    My budget is around 800$ - 1300$ cad.
    I prefer New as much of possible.
    I can be a convertible or 2 in 1 or tablet PC. But has to be windows OS.
    • 5 to7-inches
    • 7.1 to 10-inches
    • 10 to 13-inches
    • Above 13-inches
    Coming from a 12 inches, i would like something around the same size .
    Canada (Quebec)
    No preference at all. I want reliability.
    Around 8 hours if possible.
    Handwriting note taking at work. A lot of note taking (One Note)! and some light programming and remote desktop. Some web surfing too.
    I need Windows because i use One note and other app for my job that require windows.
    One Note most of the time, Visual studio on rare occasion (light programming), Word, Excel, chrome,notepad++
    no
    no
    Screen Specifics
    At least 1080p
    I will use it indoor but the pen need to work with a matte screen protector.
    Yes as this is the sole reason for me to buy a new device.
    I have read Wacom EMR are better, if so, i would like an EMR.
    Component Specifics
    120gb minimum for the drive and it must be a SSD. Memory should be 8gb minimum. My pavilion only have 4gb and i found the tablet suffering from it. It does not need to be expandable for the memory, but the drive should be replaceable.
    I need at least one full-sized USB, the rest can be of any form factor. It need to have an SD card slot, micro or not.
    Misc
    I need WiFi connection and a keyboard/mouse-pad with a descent build/feel quality.
    I would like palm rejection as i will be using most of the time a pen to take note. When writing with my pavilion sometime it skip stroke, it is really annoying, i don't want to be stuck with something similar.
  2. Starlight5
    Starlight5 Yes, I'm a cat. What else is there to say, really?
    676
    221
    @nyrull check out Thinkpad L380 Yoga (or L390 Yoga which is basically the same). It is AES 13.3" FHD, but within your budget you'll probably get EMR only in some older machine. L380Y/L390Y is a well-built machine with decent keyboard, reliable and easy to service, comes with quad-core CPUs (there are some dual-core configurations - definitely skip them!), upgradeable to 32GB RAM; on the other hand, it lacks Thunderbolt which is a pity. Hope other users will offer some EMR alternatives.
  3. nyrull
    Its a nice device, but i am not sure about the keyboard. It say that the keyboard is not lock in tablet mode, so it will probably cause problem when having it on my lap and as for AES, i am having a lot of ink skipping with my actual hp x2-12. Is it related to my device dying or it will be the same on all AES ?
    Edit: thank you for the help !
    Starlight5 likes this.
  4. Starlight5
    676
    221
    Keyboard locks in tablet mode but the frame doesn't protrude from the chassis to make flat surface like on more expensive models with Lift'n'Lock keyboards. As owner of one, already have a few pieces broken off the fancy protruding frame which is sorta annoying and won't likely happen to traditional keyboard; moreover that, Lenovo dumped Lift'n'Lock in their latest flagship X1 Yoga 4th Gen in favor of traditional keyboard, which tells a story, sorta. The fact that L380Y keyboard is not spill-resistant is much more of a problem in my opinion - but on the other hand it is very easy to replace, and should be cheap.
    Could also be crappy drivers - Wacom is notorious for them after all. I have no problem with AES on my TPY260; hated old EMR on my prior machines because of parallax and edge calibration, it annoyed the hell out of me. New EMR machines don't suffer from this but they are rare and expensive and/or lacking. Check out Samsung Notebook 9 Pro 2-in-1 - I personally wouldn't recommend one because they are nowhere near Thinkpads (or HP Elite/books, Dell Latitudes) in terms of quality, but they do have EMR.
    nyrull likes this.
  5. nyrull
    Ho, ok i tough they where saying the keyboard was no lock, but its my lack of understanding English :)
    On hp support site i don't see any specific driver for the pen, device is pavilion x2 - 12 b017ca, could it be : Intel Integrated Sensor Solution Driver ?
  6. Starlight5
    676
    221
    @nyrull try uninstalling your Wacom Device driver via Device Manager, default Windows driver may work better. You will know the correct drive is applied when your digitizer is recognized as USB Composite Device instead of Wacom Device. It will loose compatibility with legacy apps but on the other hand may resolve digitizer problems if they are caused by software not hardware.
  7. nyrull
    It is already recognized as USB Composite Device because i never found the supposed driver for the device, so i have let windows take car of it.
    Edit: It is under Universal Serial Bus controller right ?
  8. Starlight5
    676
    221
    @nyrull it is under Universal Serial Bus if you're running native Windows driver (as USB Composite Device), or under Human Interface Devices as Wacom Device if Wacom drivers are applied. Try this driver as a last resort. Now I understand why you hate AES. )=
    nyrull likes this.
  9. jjsa1985
    jjsa1985 Scribbler - Standard Member
    193
    123
    I believe the hp pavilion has an elan implementation of wacom aes, much like the Lenovo miix 700, which is why the digitizer is poorer than true wacom aes and also does not support wacom drivers, even if wacom aes pens work on it. I may be wrong, so please correct if that is the case.
    nyrull and Starlight5 like this.
  10. nyrull
    I dont see any wacom driver under Human Interface Devices and there is a USB Composite Device under Universal Serial Bus . Wacom driver won't install.
    You are correct, it is a Elan AES and i guess there is no specific driver for it.
    Edit: I don't see any driver on hp support site specific to the Elan AES or anything related to AES but looking at the Lenovo miix 700 there is a driver update that enable wacom aes pen. I could try that at this point.
    Description: Miix700 Touch Firmware (Enable Wacom AES Pen) for Windows 10 (64-bit) - ideapad Miix 700-12ISK
    Edit 2 : Ok that seem too be a bad idea, its not a simple driver but more like a bios update.
