Clicking Sound While Playing Music
Discussion in 'Hewlett Packard' started by newooub, Jul 13, 2008.
  1. newooub
    newooub Pen Pal - Newbie
    For TX2500, does anyone heard some sort of cracking sound (like the sound when you turn off then on the speaker) while playing music, like once every 5 minutes; and when you push the mobility center screen button, but not when I open it from control panel?
    I already turn off the a band, so that's not the problem. I heard the clicks over both the built in speaker & a headphone, so it's not a problem with the speaker or headphone. The sound is rather faint, so it's more noticable when I used my headphone. And, I also didn't max out the volume.
  2. Rex Orbis2
    Rex Orbis2 I Bleed Black and Gold
    44
    Its a conflict with the wifi card. You need to go to your device manager and disable the "A" band to stop the clicking.
  3. Cadaeic
    Cadaeic Scribbler - Standard Member
    123
    He already tried that.
  4. newooub
    The clicking sound is similar to the one caused by A band, but it's less loud, less often and usually has only one click, instead of several clicks when a band is on.
    Also, can someone try pushing the mobility center screen button repeatedly while playing music? I want to check if it's just my button that produces cracking sound.
  5. Jpwinks
    Jpwinks Pen Pal - Newbie
    39
    I noticed the same issue in Itunes. couldnt tell you what it is but it doesnt happen often.
  6. Farso
    Farso Pen Pal - Newbie
    Do you happen to be running IE in the background while your listening to music? Could be a frame in a webpage reloading?
Similar Threads - Clicking Sound While
  1. WhenUtry
    970
