Choice between Fujitsu T730, T4410 and T5010?
Discussion in 'What Tablet PC Should I Buy?' started by Welsinki, Nov 3, 2012.
  1. Welsinki
    Welsinki Pen Pal - Newbie
    1. What is your budget?
    €500
    Yes
    13-inches
    Europe
    From my research, Fujitsu looks like the best choice for pen quality.
    n/a. I will mostly be using it plugged in.
    Photoshop CS5 working on around 15 images at a time.
    I currently only use Macs but I have used Ubuntu exclusively for a year in the past and I like Windows 8 so the machine will probably be loaded with Windows 8.
    Windows 8 + Photoshop CS5
    No
    n/a
    Screen Specifics
    The best I can get.
    No
    Multitouch + Wacom with pressure sensitivity
  2. Pesho
    Pesho Pen Pal - Newbie
    45
    Fujitsu T730 of course.
  3. Steve B
    Steve B Moderator Moderator
    3,171
    363
    151
    The t730 isn't 13", but it might come with multitouch as well as Wacom, as its newer. The other two are 13" screens but have no multitouch options, asfaik. That's really the breakdown.
    If you want 13" screens and multi-touch, you need to look at the t900. It might be in your budget range.
    All 3 should do what you want in terms of specs, imo, though clearly the t4410 is the oldest of the bunch. If you've got the money though, go for the t900 or the t730, as they're the newest.
  4. Welsinki
    Thanks Pesho and Steve B. I'm pulling the trigger on a used T730 from Germany. In the past I've used an Intuos4 and a Yiynova MSP19 but I think it's time to get something a bit more flexible.
  5. Leopleurodon
    Leopleurodon Pen Pal - Newbie
    Hey Welsinki,
    did you get your T730?
    I also live in Germany and have almost the same requirements to the tablet I'm going to buy (see my Thread here). So I wonder if you're happy with the T730 and if there's something that's not good about it.
    Due to the fact that I never owned or even tried a convertible I can barely say if 12,1" is enough for me or if I should go for the T5010 and lose multi touch.
