Cheap and Easy EP-121 Replacement Stylus with Button
Discussion in 'EP121 Slate' started by gork1rogues, Feb 12, 2013.
  1. gork1rogues
    gork1rogues Pen Pal - Newbie
    It definitely should be in a different thread. I will ask in one of the longer running threads to see if the information could be obtained. Someone previously opened my ep121 and upgraded some parts but completely removed the cable. Anyways that is enough cable talk for this thread, thank you for the feedback.
  2. Sacardo
    Sacardo Pen Pal - Newbie
    22
  3. Marty
    3,187
    2,826
    Do these have same dimension as the stock pen?
  4. purplepeopledesign
    purplepeopledesign Scribbler - Standard Member
    359
    Don't know. I bought these for my Toshiba tablet. The body is the same 9mm diameter as the stock Toshiba pen but the the little lanyard loop prevents full insertion in the holder.
    :)ensen.
  5. gork1rogues
    Nice. I must have overlooked your find on here. Color isn't too bad on those and the price is better. Call me picky, but I don't care too much for the factory white pen and white back cover.
  6. p0g18ry
    p0g18ry Pen Pal - Newbie
    Hello! I am rezzing this thread because I lost my stylus and am too cheap for my own good to outright pay $40 for a new stylus and I need some advice. Will any old wacom pen work on our tablets? The one from the Surface Pro worked but a Bamboo one did not and I am in a pinch since I lost my stylus. I found this off ebay: New Gateway E 155 E 155C Wacom Executive Stylus Pen 5 Extra Tips Eraser 6621 | eBay Should this one work? I'd really love it if it could; I'm not even worried about it fitting in the slot. Thanks!!!!
  7. Michaelk42
    Michaelk42 Giant Robot Pilot
    Nope, Bamboo pens won't work (I have an older and a pen and touch, they don't eve interchange between the two Bamboos actually.) You need the UP/Ultrapen/Penabled type of stylus.
    However, I bought that EXACT pen from those very people in your Ebay link, and it works on my EP121 just fine. Obviously it's not going to fit in the silo (it has that raised ridge that I assume made it click into place in the Gateway tablet, and it's about 2cm shorter than the stock UP-model stylus) but I don't keep it in there anyway.
  8. Steve S
    7,708
    3,197
  9. p0g18ry
    You are awesome! That's exactly what I needed to know.
    Thanks for finding that post! I knew we had one out there; I was just struggling to find it.
  10. p0g18ry
    I ordered this as well and it worked! $10 only for a direct replacement WITH a right click button and eraser functionality. True, I had to file off the raised part on it, but that only took about 5 minutes and a lot of patience. Definitely worth the money if you need a spare or a replacement.
