Cases/Sleeves/Stands for Asus Vivotab Note 8
Discussion in 'Asus' started by replax, Mar 7, 2014.
  1. Kumabjorn
    4,449
    2,624
    You'll want to hold out in one hand anyway when you're inking.
  2. sudermatt
    sudermatt Scribbler - Standard Member
    345
    My ibyson click on case mod for easy pen access....,makes all the diffsrence. be sure to give yourself plenty of room. basically, you will want to clip back to where the plastic openings for the pen are.
  3. fureien
    fureien Pen Pal - Newbie
    48
  4. pyro6128
    pyro6128 Pen Pal - Newbie
    19
    I got this same case. What a terrible oversight it was making the pen so hard to get to.
  5. alvarez13
    alvarez13 Scribbler - Standard Member
    177
  6. thatdude90210
    thatdude90210 Pen Pal - Newbie
    96
  7. fureien
    48
    because the construction clearly looks quite cheap
    just look at the stitching of the base. ive seen cases like that before
    literally "pleather" made of cardboard
    so fake-fake leather and stitching that falls apart
    I could be wrong, but my experience suggests this is why
    Also wholesale prices of cases are like $1
  8. Yotami
    Yotami Pen Pal - Newbie
  9. vinscuzzy
    vinscuzzy Pen Pal - Newbie
    Unfortunately the first 2, like you said, are IVSO clones, so yes they have magnets. I bought one of these cases from amazon and they are completely unusable with the pen. Horrible design, but i was able to remove the magnets pretty easily. They're not glued in, just pressed in. The magnets only go about an 8th of an inch deep, so with a very thin eye glass screw driver, I popped them out with minimal damage to the plastic housing.
  10. whyired
    whyired Pen Pal - Newbie
    Anyone have additional feedback on the Versasleeve for the note 8? I ordered one along with the actual tablet but wondering if should have got something else.
    Much love.
