Can't get the bluetooth control panel applet
Discussion in 'Fujitsu' started by Bhaltair, Dec 2, 2006.
  1. justauser
    justauser Scribbler - Standard Member
    183
    I cannot get the bluetooth control panel apple to display. I installed the driver on my 4215, but no applet. Any ideas how to get this enabled? I do have the power on to the device.
  2. Barry J. Doyle
    2,153
    Are you looking in the Windows control panel? Also, did you buy an add-on third party module or are you referring to the built-in Fujitsu BT radio?
  3. justauser
    183
    OK, figured it out. When you insert the CD with the Bluetooth stuff on it it runs some auto install. This *does not* install everything you need. You have to go to the CD with Explorer and install the Toshiba Bluethooth stack and the driver. Did that and now my Windows Mobile device can bluetooth sync.
  4. Bhaltair
    Bhaltair Pen Pal - Newbie
    45
    I ran into the same problem with my ST5030.
    I also didn't have it turned on with the bios.
    I also think Fujitsu installed the wrong chip since when I complained about it when returning the unit for repair (screen cover issues, blank screens which I'm still having) they replaced it.
