Can't draw on part of screen
Discussion in 'Windows 10' started by Ma701ss, Feb 2, 2017.
  1. Ma701ss
    Ma701ss Pen Pal - Newbie
    Hi, I've just bought a Windows 10 8" tablet and it works fine, I can tap anywhere on the screen and it responds. However, in any drawing/sketch app there is a vertical area of the screen about 1cm wide, to the left half of the screen. If I try to draw a line over this area it blanks it out. If I scribble all over the page it leaves a blank area with perfectly straight edges. Must be a software rather than hardware fault, as I can tap on icons in this area at other times and it responds.
    Any ideas? The manufacturer isn't responding and the supplier doesn't know.
  2. XJ12
    XJ12 Scribbler - Standard Member
    443
    112
    Is there any calibration software for the digitizer?
