Can active digitizer be turned on/off to help with stylus battery drain?
Discussion in 'Dell' started by bugelrex, Jan 7, 2014.
  1. bugelrex
    260
    44
    Perhaps it could be configured to turn on ONLY when onenote is running and turned off when close? A custom program which sends the on/off commands depending on what programs are running.
  2. Mesosphere
    5,279
    1,956
    I don't know the answer for certain, but I'm doubtful since the Synaptics system doesn't use a separate digitizer for it's pen, it is simply an extension of the capacitive sensor to pen input unlike Wacom where the two digitizers are two separate pieces of technology. Probably not conclusive enough to be helpful to you though =)
  3. Mikerman
    1,293
    126
    Had thought the same thing--why not simply an on/off button on the stylus? Seems logical for any device (silly me).
  4. eternal
    eternal Scribbler - Standard Member
    118
    yea they really do need to add an on off button to the pen.
    mostly because theyre liars about the year long usage from one battery
