c200 series CPU upgrade?
Discussion in 'Acer (Gateway)' started by MCW, Jan 11, 2007.
  1. MCW
    MCW Pen Pal - Newbie
    54
    Can the CPU in the c213 be upgraded? - It's nt soldered to the board or anything is it?:confused:
    Anyone actually ever successfully unscrewed and opened a c200 series? - Any advice?
  2. Gautam
    Gautam Moderator
    484
    I thought only Macs have soldered CPUs. I may be wrong. Anyone?
  3. MCW
    54
    Well I was just asking because I hear that some UMPCs and smaller notebooks have them soldered on board - I just wanted to be sure and make sure I don't spend ages taking it apart for nothing :p
  4. Gautam
    Gautam Moderator
    484
    Oh, that's true. I forgot to mention that. BUT the c200 series is neither an UMPC nor an ultralight notebook, so I don't think it should be a problem.
  5. MCW
    54
    yeh, that is true.
    Thanks for your input .. I only hope your right :p
  6. Hackman
    Hackman Pen Pal - Newbie
    The c200 series have an 915pm or 915gm chipset. That one support at maximum 133mhz fsb (533mhz). That mean that you can put inside every pentium m cpu (up to 780 (2,26 GHz)). These are listed as supported on the official acer homepage.
    The most interesting thing is, that there are 2 core duo cpu that are also supported from the chipset but not officialy supported by acer.
    One of them is the T2050 (2 x 1.6ghz)
    An example with the 915 chipset you can see here:
    http://www.yatego.com/tuning-team/p...4,notebook-17-zoll--core-duo-t2050-2x-1-6-ghz
    And the fastest cpu that maybe work in the c200 is the T2250 (2 x 1,73ghz)
    There exist an acer notebook with that combo ( 915pm chip and T2250 cpu)
    http://notebooks.neoshop.ru/show_notebooks.html?notebook_id=634
    When you can get that cpu, please try it if it work or not.
  7. danbrow
    danbrow Pen Pal - Newbie
    the bios has too support the cpu for the upgrade too work. Check acers ftp to see if they added support for any of core 2 support in a recent bios.
  8. MCW
    54
    Oh, damn, I meant to say its a c213, so already have a T5500 Core2 Duo in it... sorry guys lol
  9. Hackman
    Yes, you can upgrade to the T7600 when you want. It is supported from acer.
  10. charlemagne
    charlemagne Pen Pal - Newbie
    Where did you find this? I'm looking to upgrade my C312 (pent m 740) and cannot find anything official. tnx
    Hackman Yes, you can upgrade to the T7600 when you want. It is supported from acer.
