C-140X Overheating
Discussion in 'Acer (Gateway)' started by Spartikiss, Sep 6, 2009.
Does the C-140X Overheat?
  1. Yes, only under intensive apps
    12 vote(s)
    15.8%
  2. Yes, both intensive and non-intensive apps
    33 vote(s)
    43.4%
  3. No, not under intensive or non-intensive apps
    26 vote(s)
    34.2%
  4. No, although I haven't used any intensive apps.
    18 vote(s)
    23.7%
  1. NetHead
    NetHead My PC almost boils water
    49
    I spoke too soon. The laptop shut itself off again last night.
    I am still waiting for them to call me to schedule an onsite repair. I will call them after my day is done to see what the deal is.
    Edit: Just for kicks, here's the last line of my speedfan logs from last night (this should be right before it crashed)
    "Seconds HD0 Temp1 Core 0 Core 1"
    "6597 54.0 96.0 80.0 81.0"
    I am assuming that's in Celsius since there are values in the 40s in some of the other files and it doesn't get that cold here in Texas :)
  2. NeoLibCon
    NeoLibCon Scribbler - Standard Member
    158
    They would only be able to tell from obvious removal of screws. With on-site warranty, though, Gateway will never see your unit. Only, in my case anyways, a contracted technician who is not loyal to Gateway.
  3. Slawek
    Slawek My new laptop smoking you
    132
    Some Locktite can fix that issue. :) Anyone sell aftermarket internal notebook coolers? or does anyone think the fan inside this thing is proprietary?
  4. playersnoopy
    playersnoopy Pen Pal - Newbie
    You better hope that's in Fahrenheit cuz if that's Celsius your computer is done for :p When you run speedfan it should show your temp like 45C, so celsius. Unless somehow your settings are changed and shows Fahrenheit your computer is running super hot. 96 degrees celsius is near water boiling point. If you run your program and it reads 96F then it's in fahrenheit and you're ok and running really cool.
  5. NetHead
    49
    Well, I caught the defect on camera.
    Gave Gateway another call and they said they just shipped the replacement fan to their technician today. (They said they would be at my place yesterday to fix it--what is up with them and estimates?)
  6. mludwig
    mludwig Pen Pal - Newbie
    38
    NetHead, could you try giving it a nudge instead of blowing it? That way you can tell, if it is the sensor or the fan that's faulty. However, it seems the fan wants to start, but it just doesn't have the right amount of kick.
  7. Spartikiss
    Spartikiss Scribbler - Standard Member
    215
    How did you get it to give you 4 readings? I only get the one for the two cores...
    -Spart
  8. NetHead
    49
    Ran under XP compatibility mode and as administrator.
    I'll try nudging the fan next time I notice the problem. Don't expect a video though, I won't have access to a camera for the next few days.
  9. bpjen
    bpjen Pen Pal - Newbie
    45
    I am noticing the problem also, I had a shutdown a couple nights ago while working off the battery.
    Here's something I am doing until a fix is announced. I downloaded the program Notebook Hardware Control. I used to use this a while back, but haven't for a while. It reports a number of temperatures and speeds, you can control some power settings, etc. What I have found helpful is that you can set the program to alert you if the processor or hard drive reach a certain temperature. A pop up window shows up, and you can set the temp you want it to be triggered by. Since I often don't hear the fan or touch the unit to see how hot it is, this gives me a cue that the fan is not kicking on. I have then just turned it over and did the "blow in the fan trick" to get it going, and it cools down quickly. The temp is constantly shown on the task bar also. Let's hope a fix is announced soon.
    Funny, it did it just as I was finishing posting this... it definitely seems that either the fan is defective, or it is not getting enough juice to start it up.
  10. gutierrez
    gutierrez waiting for a fixed fan
    77
    Please do contact gateway and let them know you are having the problem if you haven't yet. Ask if there is a fix other than sending it in if you don't want to send it in. The more evidence they get there is a real problem, they more likely a fix will be on the way.
    I'm hoping they are working on mine right now and it will be back to me soon... without any cooling problems.
