C-140x for Art / Design issues - Solved
Discussion in 'Acer (Gateway)' started by Meltdown, Aug 27, 2007.
  1. chriscannon
    905
    yeah... I dont know what you guys were trying todo in Photoshop, but I dont have any calibration issues. I have the intel chip, and only the drivers from gateway's website. Tell me exactly what you tried on yours, and ill try it on mine.
  2. waplespunk
    waplespunk Scribbler - Standard Member
    169
    Simply run Photoshop. If your cursor is normally under your pen, and in photoshop, it isn't anymore, you have the issue.
    A good test is to have the tablet in laptop mode so you can use the keyboard. Hover the pen just above the screen and don't move it. Now alt+tab between photoshop and your desktop. With us, the cursor will jump between right under the pen tip to somewhere else from 2-10 pixels away.
  3. waplespunk
    169
    I DID IT!!! Well, I didn't, but Wacom did (after I paid long distance fees to tell them stuff)
    This Works.
    It only worked after I rebooted.
    Man am I happy!
    So none of you cancel your orders.
    If you don't know how to do this, here is a step-by-step:
    1. Click on Start, then Run, then enter RegEdit in the Open textbox and click OK.
    2. Click KEY_LOCAL_MACHINE then SYSTEM then CurrentControlSet then Services then TabletServicePen then PARAMETERS.
    3. In the right-hand window pane, right click, then click New and then DWORD.
    4. In the new dialog that opened, type WTKernelBypass, then click somewhere else to let it fill in.
    5. Close the Registry Editor.
    6. Reboot, then run Photoshop.
    7. Kiss my butt and send me your money :D
    8. Keep this in a place you won't forget it in case you ever need to reboot.
    Hope it works for you guys!
  4. zeb
    zeb Pen Pal - Newbie
    it fixed it on all the apps I'm using, photoshop, painter, Zbrush and Modo.
    Great fix :)
    only thing is that I had no TabletServicePen service, only TabletService...
    I guess you did a typo error :)
    anyway IT WORKED
    kiss :))
  5. tabletonthevista
    tabletonthevista Scribbler - Standard Member
    232
    chriscannon: The guys that are having the calibration problem are using the Wacom drivers (because they want the pressure sensitivity that is not available in the default drivers).
    waplespunk: Do you want to try to explain the Wacom explanation? I'm confused by what they said about disabling the flicker or pahtrc thing. :D Yes I know that it's just adding a key to the registry, but I still want to know what they had to say about it.
  6. nikecar
    1,524
    i have intel and its off for me. top toolbar area is spot on, go on the paper and the farther down you go, the more to the right it veers off for me.
    its a WACOM Driver issue, nothing about the PC.
    i too would like some extra confirmation on this.
    Art Rage is fine for me, PS is off, Illustrator is off for me too the farther down you go.
  7. nikecar
    1,524
    now rebooting.. wish me luck
  8. Nominal
    Nominal Engineering Student
    199
    Good Luck ;). I hope this works.
    If so, maybe those lucky ones of us who's tablets haven't shipped yet will never have to deal with this issue.
  9. nikecar
    1,524
    nope.. still the same after a reboot and wap's instructions...
    EDIT.. wait.. i typed the new entry in the tablet line, not the parameter.. will re attempt...
  10. nikecar
    1,524
    Ladies and Gentlemen.. i am sory, but i have to say...
    IT WORKS!!!!!!!
    ITs basically spot on, considering what your normal screen calibration is, and the pressure sensitivity is working too.
