Business/School Laptop w/ USB-C?
Discussion in 'What Tablet PC Should I Buy?' started by Theme57, Jun 17, 2018.
  1. Theme57
    Theme57 Pen Pal - Newbie
    39
    1. What is your budget?
    $1500, but would prefer around $1000
    Yes
    No
    • 10 to 13-inches
    • Above 13-inches
    USA
    None
    6 - 8 hours minimum, 10+ hours preferred, but not required.
    School use primarily.
    Windows.
    Clip Studio Paint and Photoshop. Microsoft Office and Python.
    Screen Specifics
    Natively don't care, but needs to support a Wacom Cintiq 24 Pro at 4K through USB-C
    Outdoors, but mostly in a classroom. Anti-Glare would be helpful, but is not a requirement.
    Component Specifics
    Min 8GB RAM with the option of an m.2 or SSD.
    full-size USB, and USB-C capable of 4K. HDMI would be nice, but is not required.
    Misc
    The laptop will be used as a primary school device for notes, typing up papers, learning python and other business/school minded tasks. I want USB-C so I can hook up a Wacom 24 Pro through USB-C at home. Storage isn't an issue on the laptop as I export data to an external drive over keeping it on the laptop. Battery life is a bit thing for me when I am out and about. At home I will have it hooked up to a dock in a multi monitor setup.
  2. Starlight5
    Starlight5 Yes, I'm a cat. What else is there to say, really?
    676
    221
    @Theme57 look no further than Thinkpad L380 Yoga (I'd recommend a 8250U or 8550U model with Fingerprint reader & world-facing camera options, yet 8GB RAM and smaller SSD - you can add RAM up to 32GB and replace the SSD yourself easily much cheaper later on. It has both 4K@60Hz USB-C and 4K@30Hz HDMI, and should cost you around $1000 without upgrades. Note that it doesn't have TB3.
  3. Theme57
    39
    Great suggestion! I can't seem to find if the RAM is user replaceable or soldered on. Wacom AES is a big pro too. I don't care for TB3 so long as it can run a Wacom Cintiq 24 Pro. Spec wise it looks really nice!
  4. Starlight5
    676
    221
    @Theme57 RAM is upgradeable up to 32GB, unlike most other machines - hence my suggestion to get 8GB version; Lenovo will charge a lot more for RAM increase than it's worth, so adding a 16GB stick yourself for 24GB total is a much better start. It's a perfect machine unless you want things like TB3 & LTE modem (X380 Yoga, X1 Yoga) and 500 cd/m2 display (X1 Yoga HDR option) - but those are much more expensive and limited to 16GB soldered RAM.
