Budget Upgrade From a Motion Computing LE1600
Discussion in 'What Tablet PC Should I Buy?' started by RecklessMaker, Jul 31, 2019.
  1. RecklessMaker
    RecklessMaker Pen Pal - Newbie
    General Questions.
    1. What is your budget?
    $300 MAX, ideally under $200
    Absolutely
    Mobile tablet
    12" or above
    USA
    Nope
    Don't care
    Notetaking
    Windows is mandatory
    Autodesk eagle, light PDF markup
    No
    No
    Screen Specifics
    No
    No
    Yes, good pen support is mandatory
    Component Specifics
    Don't care
    Don't care
    Misc
    1. Other non specific items ~ please add other items you require not covered above?'
    Per the title, I currently have an LE1600. While I really like the form factor and digitizer, it is molasses slow. So essentially I'm looking for an LE1600 that can keep up in 2019.
    If it can use a keyboard, it must be detachable.
  2. Starlight5
    Starlight5 W I N T E R B O R N
    675
    221
    @RecklessMaker you can score Lenovo Thinkpad X1 Tablet 1st or 2nd Gen, Toshiba Portege Z20T-B or Z20T-C, HP Elite X2 1012 G1 within your budget. All these are tablets with detachable keyboards; Toshiba is EMR, while Thinkpad & HP are AES. I definitely suggest at least 8GB RAM versions, maybe 16GB RAM if you find it on the cheap - unlike SSDs, you won't be able to upgrade it later. All these tablets have Core M CPUs - somewhat faster than what you can find in Surface Go, but behind modern quad-cores; still, either will run in circles fly faster than light around your LE1600, performance-wise.
  3. RecklessMaker
    @Starlight5 That was actually quite prescient as I ended up going with this HP Elite X2 1012 G1. It seemed like a good deal and so far I really like it. You're absolutely right about it annihilating the LE1600 performance-wise lol.
    Starlight5 likes this.
Similar Threads - Budget Upgrade Motion
  1. Fritomaster
    1,102
  2. Mr. Boosh
    1,198
