Bluestacks on Surface Pro 3
Discussion in 'Microsoft' started by r11, Jun 30, 2014.
  1. FZelle
    771
    184
    And what has that to do with this?
    Running Android Apps on a W10 Mobile device is a completely different story.
    W10 Mobile comes with a runtime that allows to run some Android software, but by fare not all.
  2. Barstuck
    Barstuck Pen Pal - Newbie
    62
    21
    I referring to running Android Apps on my SPro3 (still on Win8.1).
    The phone referral was just (unnecessary?) background info that I will be moving away from my only android device, but still want access to some of the apps.
  3. Mr. Boosh
    Mr. Boosh Scribbler - Standard Member Senior Member
    839
    297
    DuOS is the best emulator solution for Android, hands down. To install Android-x86, you'll need to feel comfortable modifying partitions and working with Grub bootloader. I can provide you with the Grub.cfg that works for the SP3. You'll need to learn everything else.
    Native Android on these Core processors is ridiculously fast and smooth, makes picking up even a year old ARM device feel sluggish. Battery drains quite a bit faster though, emulator or not.
    Barstuck likes this.
  4. GiGo
    GiGo Pen Pal - Newbie
    59
    I've been using DuOS for the last year, pretty much the first program I purchased after buying my SP3 and after reading about it.
    TBH I have no real use for Android on my SP3, for all things Google docs etc... I tend to grab my Chromebook instead of my tablet.
    But DuOS gets my vote if you want Android on your PC!
  5. Barstuck
    62
    21
    DuOS has been working pretty good for me the last week, though it does make my SP3 run hot and kills the battery pretty quick.
    Only real downside is that it is not free. :confused:
