Bluestacks on Surface Pro 3
Discussion in 'Microsoft' started by r11, Jun 30, 2014.
  1. jb82
    jb82 Scribbler - Standard Member
    148
    27
    Duos sends my surface i3 into a heat and fan frenzy! wow it gets hot and noisy.
  2. ecoeco
    ecoeco Pen Pal - Newbie
    70
    I've found Andy (the android simulator) to run a little smoother and a little quieter on my SP3 i5. Duos was a little jerky and slower to respond.
    Sent from my iPad using Tapatalk HD
  3. JLinz
    JLinz Pen Pal - Newbie
    Based on this and other suggestions, I installed and tried out Andy. However, I found it to be about equally resource intensive with no appreciable improvement in performance. Waiting for Console OS . . . .
  4. Malamasala
    Malamasala Scribbler - Standard Member
    102
    Tested Andy myself. First time I got my Surface Pro 3 hot. (Weirdly enough it started in the installation process even.)
    Seems tricky to do this without better cooling.
  5. r11
    r11 Scribbler - Standard Member
    170
    I gave up on trying to get Android apps to run under Windows on SP3. Found workarounds for most apps, had to forget about others. Only app I genuinely miss is Mantano Reader. For now, I use stock Reader for PDF and Bazar Reader for epub.
    The only hope we have of ever being able to run Android apps under Windows without having 40% CPU usage is the native x86 Android, but may be even that is not doable. Booting SPro straight into Android would definitely be wickedly fast, but dont you loose all the Windows apps till next reboot. Sux and I wont do it.
  6. WilliamGreen
    WilliamGreen Pen Pal - Newbie
    They explained it here, watch this
  7. crashnburn
    crashnburn Scribbler - Standard Member
    142
    How has this worked? Anyone tried it on SP3?
  8. Grbspltt
    Grbspltt Pen Pal - Newbie
  9. Dr. Boosh
    Dr. Boosh Scribbler - Standard Member Senior Member
    887
    344
    If you need Android and Windows together, run an emulator. If you know what you're doing and want native Android, Android-x86 4.4-r3 and unofficial Lollipop builds run perfectly on the SP3 except for rotation sensor.
    Full, native Android, 55,000+ Antutu score on the i3.
  10. Barstuck
    Barstuck Pen Pal - Newbie
    62
    21
    If you don't know what you are doing, how difficult is it to learn to install and use Android x86?
    I've read reviews that Andy contains Spyware or Mallware. Can anyone confirm this? I've tried (admittedly briefly) Bluestacks and it appeared to be for games only. Never tried DuOS.
    I am hoping to move over from my Android phone to Windows when the new Cityman is released, and there are a couple apps (*cough* games *cough*) that I would like to continue to use.
    (note: not just games, or Bluestacks would be fine)
