Bitlocker issue
Discussion in 'Windows 10' started by bloodycape, Feb 23, 2016.
  1. bloodycape
    2,821
    432
    I had some bltlocker issues; so, I turned it off to turn it back on again. However, I can't get it to turn on again. I get the error message something went wrong, try again. I did, but so far no dice. I tried to google it, but some of the answers are for Windows 8, and didn't work. One suggestion I check my bios firmware, but I think I have the latest one for the Surface 3. Any ideas?
  2. bloodycape
    2,821
    432
    Okay I restarted my computer and now I noticed in device manager that it says TPM2.0 is has an errors. Says requested device is in use. Any ideas?
  3. Steve S
    8,390
    3,886
    <<...Any ideas?..>>
    ...Do some research on resetting / clearing your TPM. There are Microsoft knowledge article on both (I think...). Clearing the TPM is a non-trivial step, so don't attempt it until you fully understand the implications!
    Good luck...
  4. bloodycape
    2,821
    432
    The issue was solved when windows installed another firmware update and update to the latest build.
