BIOS Settings for Gateway M285-E
Discussion in 'Acer (Gateway)' started by Waynehjr1, Jul 30, 2010.
  1. Waynehjr1
    Waynehjr1 Pen Pal - Newbie
    Does anyone know if there is a BIOS update that will allow more versatility for the settings inside the Gateway M285-E Tablet PC?
    I ask this because I am in the process of upgrading my Gateway M285-E. I'm waiting for the new 'Seagate Momentus XT 500gb ST95005620AS Solid State' & '4GB RAM 2x2GB DDR2 200 Pin PC2-64000 800MHz Memory' to arrive.
    I actually have already installed the T7600G (2.33GHz) Processor, which allows for overclocking up to 3.16GHz.
    The existing BIOS does not allow for any alterations to the CPU. I am just curious if there might be a way around this.
    I am planning on installing Windows 7 OS when the HD arrives. I am not sure if that will change the BIOS at all, yet, until I actually install the OS.
    Any information will be helpful.
  2. Waynehjr1
    Well I have finally received and installed 'Seagate Momentus XT 500gb ST95005620AS Solid State' & '4GB RAM 2x2GB DDR2 200 Pin PC2-64000 800MHz Memory'. They all work fine with one exception, I have to use Vista instead of Windows 7. I tried installing Windows 7 64bit and it will install all the updates except for the 'Finepoint Inovations' upgrade. It keeps on failing to install. Is there a fix for this somewhere?
  3. Spartikiss
    Spartikiss Scribbler - Standard Member
    215
    Sounds like a bad install of Win7 or a bad copy of the driver...
    Try downloading both again and reinstalling.
    -Spart
  4. NamelessPlayer
    905
    73
    FinePoint...that's the pen digitizer used in those first-generation Viper convertibles, and also the one used in the Compaq TC1000.
    I don't know much about it, but in addition to needing a pen battery, its software support appears to be noticeably lacking compared to Wacom (which, coincidentally, both the second-gen Gateway Viper convertibles and the TC1100 use, along with almost every other Tablet PC on the market).
    Is the Vista version in question 32-bit? That might explain it, for if FinePoint hasn't produced any 64-bit drivers, you're SOL on 64-bit Windows and will have to go for 32-bit Win7.
  5. crotaphiticus
    crotaphiticus Pen Pal - Newbie
    Does someone have the link for the appropriate cpu ( ebay)? Will this need bios updates?
    thanks
