Big problem with touch screen- orientation mirror effekt
Discussion in 'HP TouchSmart TX2 (N-trig)' started by npadres, Feb 5, 2012.
  1. npadres
    npadres Pen Pal - Newbie
    Tx2500/Windows Vista
    Touchscreen Orientation wrong
    When Im moving the cursor down, it goes up. When I'm moving the cursor up, it goes down, the right-left,
    like a mirror effekt!!
    The x and y - axis is wrong.
    Please help
    Software from HP does not help.
    What is wrong whit me HP2500 I'm devastated
    I updated everything possible.
  2. Agent 9
    5,376
    That's your issue. Basically try simply uninstalling the Wacom driver and re-installing the Wacom driver Tablet PC - Enhanced Graphics Driver (if that doesn't work then try re-installing the video driver as well)
  3. npadres
    Hei Agent 9. I tried to re install Wacom driver Tablet PC
    But still the touch screen responds inversely!! I make new instalation Vista, format
    Touch screen is broken????????
    give any advice!!!
  4. npadres
    pleaseeeeeeeeeeeeee
  5. Steve S
    8,107
    3,627
    <<...When Im moving the cursor down, it goes up...>>
    ...Please provide some additional details. How are you moving the cursor? A mouse? Touch?
    Are you in landscape or portrait mode?
    Did you do anything immediately before this started to occur, such as install a program or some Windows updates?
    Finally, have you tried to see if you can run a System Restore to a date before all of this started happening?
    (The only time I've seen anything like you describe is when I accidentally tried to use my mouse upside down...!)
  6. npadres
    When Im moving the cursor (finger and pen) it go opposide
    Mouse works fine
    works opposide in any position landscape
    When the system is clean and graphics drivers is not installed even then Touch Screen responds inversely.
  7. Steve S
    8,107
    3,627
    <<...When Im moving the cursor (finger and pen) it go opposide
    Mouse works fine...>>
    ...It's been a long time since I used Vista, but have you tried recalibrating?
    Control Panel (View by large or small icons) > Tablet PC Settings > Display Tab > Reset, then Calibrate...
    (These instructions are for Windows 7, but Vista should be similar)
    Calibrate for Pen Input and see if that makes any difference. If not, my advice would be to contact HP Tech Support...
    Good luck.
  8. npadres
    I tried Calibrate but when I calibrate also orientation is wrong
    I tried 3 programms to calibrate
  9. Steve S
    8,107
    3,627
    <<...when I calibrate also orientation is wrong...>>
    ...The only thing I can think to suggest is that you contact HP Tech Support. Possibly another forum member has a bright idea?
    Either way, good luck.
  10. npadres
    thanks Steve
