Best Tablet for Online Maths Tuition (using OneNote)
Discussion in 'What Tablet PC Should I Buy?' started by wrighty, Aug 14, 2018.
  1. wrighty
    wrighty Pen Pal - Newbie
    Hi,
    Based in UK. Searching for first tablet and a bit lost with what to go for.
    I am looking for a tablet that has the following features (the features are also ranked roughly according to importance)
    - works well with MS OneNote
    - fast and reliable internet connection
    - 3.5mm jack (as I will be using putting inserting own speakers and headset
    - responsive to most stylus pens (I am sure this is rarely an issue with most tablets)
    - either large memory (>=64gb) or USB slot (so I can plug in hard drive if needed, which contains several gb of my tutoring resources on it)
    - preferably no more than £250/$320/300Euro
    - minimum 8" screen
    - good camera quality desirable (not essential as I will often be using skype to share my screen anyway)
    Just looking for a head up as to what you guys think is best.
    A model I am considering is Xiaomi Mi Pad 4, although sold widely in UK.
    Looking forward to hearing from you.
    Thanks
    J
  2. Cuberdon75
    252
    199
    Cube Mix Plus
    Acer Chromebook Tab 10 if you're willing to tinker (as you could only use the MS version of OneNote through Crossover on Linux). Android OneNote works directly.
    Both use Wacom EMR stylus technology.
