Best Tablet for an Artist?
Discussion in 'What Tablet PC Should I Buy?' started by Firefairy, Dec 31, 2008.
  1. Firefairy
    Firefairy Chaos Artist
    First, the cut-and-paste:
    General Questions.
    1. What is your budget?
    Exactly $1500 (Xmas present, I'm stone broke otherwise.)
    Convertible would be nice, but other considerations are more important.
    * Small and light ~ 5" to 8.9"
    * Compact ~ 10"
    * Mainstream ~ 12.1"
    * Large ~ 14"
    Definitely Large- screen real estate is a major concern. I am very worried about the idea of drawing on a screen that is smaller than a sheet of notebook paper, although I do see other artists buying the 12" screens...
    US
    I love Wacom tablets.
    A few? Enough for a decent sketching session away from an outlet.
    Drawing and computer art primarily, with secondary use in Office and web access.
    I would prefer XP, not a huge fan of Vista.
    Painter IX, PhotoImpact X3, Office 2k3, Firefox, Thunderbird.
    Being able to run GuildWars would be nice, but is definitely not essential.
    Screen Specifics
    Standard if possible, better aspect for drawing.
    * XGA - 1024x768 ~ Large and easy to read text and graphic icons but you fit less on the screen.
    * SXGA - 1400x1050 ~ Small text and graphic icons which require good vision but the gain is a much larger screen. (no longer available new, must look for used or refurbished machines)
    * WXGA - 1280x768 ~ Wider viewing angle of XGA but ideal for viewing Spreadsheets and other programs that require desktop space. (Only resolution available in new tablets circa mid 2008)
    SXGA or WXGA- as high-res as I can get.
    See explanation below for guidance.
    Indoor/Outdoor would be much preferable, I like drawing landscapes. Shade is usually available, however.
    Definitely Active. I need a pen, and I don't like finger-touch controls at all.
    5. Do you require Wacom, Finepoint, or N-Trig Technology?
    As mentioned, I would much prefer Wacom, but the key is good quality and responsiveness.
    Component Specifics
    Probably any modern Tablet will have enough HD, maybe 100G minimum to be safe? Memory, as much as I can get, minimum 1G or so.
    It would help a lot with backups and installs, but I can get an external if I need to. Pen and Graphics quality are much more important.
    Again, would be very nice, but not the prime consideration.
    Misc
    My chances of being able to replace this if it dies are pretty much nil, so sturdiness and/or a good warranty (if there is one to be had) are important. I plan to baby it, but I really need to avoid models with major known problems. I will be using it a lot, but I don't currently have much of a schedule, so having to send it away for service would be unpleasant rather than impossible.
    I don't know if it's even possible to get one without any more, but onboard wireless helps a lot. More relevantly, I would like one with some forward compatibility, so up to 1k would be good.
    I don't really need much in the way of security features to protect my data, such as fingerprint locks, but theft prevention features would be much appreciated.
    I don't care if it is heavy, I am a sit-down-and-draw type anyway.
    I don't care if it is the latest model as long as it can do what I need it to do. The TravelMate C310s were my running favorite when I first started daydreaming about this, but I figure I might as well consider some of the more recent models. The Gateway C-143XL was looking pretty good, but the reviews I have seen of it don't look so hot, and as it won't run the most recent edition of Photoshop, I'm worried about its capabilities with Painter and PhotoImpact.
    I am basically buying this as a drawing pad with computer capabilities on the side. What should I get? :confused:
  2. Firefairy
    Looking at the other threads and reviews, I must admit that the Fujitsu t4220 looks pretty yummy, and there are some on eBay in my price range... I'm still a little paranoid about the screen size, though. I had a 12" iBook for a short while (I am so not a Mac person), and the screen drove me nuts with its eensyness. Maybe it was the low resolution bothering me, rather than the size?
  3. freedomeagle
    freedomeagle Pen Pal - Newbie
    92
    I'm a cartoonist and I'm used to a Cintiq, so I find the 12" screen a bit restrictive when pencilling and inking. If you like drawing nice big sweeps you'll soon get sick of barrelling off the edge of the screen.
    I'd go for a tablet with a 13.3" inch WXGA screen if you can. You will really feel the benefit. The Asus R2E is all right and has a lovely screen for drawing on with a very pleasant "tooth" to it (though battery life not great without the modular battery), the Fujitsu T5010 is a true luxury item at that size but outside your budget I think.
  4. Firefairy
    Darn, that's exactly what I was worried about. I barely manage not to inadvertently go off the edge in my (dead trees) sketchbook most of the time, and it's bigger than even the largest tablet screens. I would love to get a Cintiq, but I'm a new artist, and at the moment, not successful enough to afford it. I figured out a while ago that a tablet PC was my best bet for getting to draw on the screen, but the small screens make me nervous, as my biggest strength is expressive line, which doesn't work very well when you have to scroll to finish a stroke.
    The eBay gods are mocking me... there is one Fujitsu T5010 for sale with a BIN price of $1550 and no shipping cost, but I literally have no wiggle room. The agony!
  5. frog
    frog Scribbler - Standard Member
    290
    14
    If you can stretch to it, I would recommend the T5010, it's a very powerful tablet with an excellent and beautiful screen. For Photoshop it's as snappy as a desktop computer and I personally wouldn't want the screen any smaller (I would think the T4220 would be quite a bit more cramped).
    Here's a sketch I painted on mine recently:
  6. Firefairy
    That's really nice... okay, time to start figuring out who I can borrow money from. If I can hit up five friends for $10 apiece before someone snaps up the one I found on eBay, I have a chance... :-J
  7. DRTigerlilly
    7,034
    381
    271
    Also take a look at the Fujitsu Outlet on Ebay you might be able to get a good deal that way.
  8. Firefairy
    <pouty lip> But... but.. but... I want one now, never mind that I could save hundreds of dollars or get a better model if I'm patient!</pouty>
    ;) Thanks for the reminder.
  9. frog
    290
    14
    Also if you do get a T5010, or indeed any other tablet, I strongly recommend you go with Vista, it's basically the best OS to use on a Tablet PC. I still have XP on my desktop, but I wouldn't consider it on the tablet, Vista is just that much better.
  10. Grimnir
    758
    I'd like to bump the T5010 here as well.
    Though I want to point out that the x4500MHD IGP does not support the OpenGL capabilities of Adobe CS4 (Specifically Photoshop CS4).
    Its not a big deal though, everything else runs fine. :) As soon as I get my designs copywritten I will post some art Iv'e done on my T5010 myself.
