Best PDF reader for making notes with a Pen (not Adobe)
Discussion in 'The Tablet PC Life' started by Variable, Aug 8, 2017.
  1. Selofain
    Selofain Chronic Lurker
    538
    305
    Lol, literally what I was going to say when I read that post. Bluebeam absolutely has the best PDF inking, but man that price. !!!
    PDF Annotator is also very good, especially since they implemented touch awareness, but it's also very overpriced at $70. The educational discount puts it at $30, which is much more fair, but I don't need PDF annotation that much anymore, so not worth getting.
    Xodo isn't bad, but it doesn't have pen pressure and I can't see the point of a PDF annotator without pen pressure. I hated every single Windows Store app with PDF inking, as they are all pretty terrible or else have no pen pressure.
    Oh, you know what? Xournal. I haven't checked on this in a long time, so I just downloaded it and it has pen pressure and writes very well on PDFs. And it's open source and free!
    Unfortunately, it seems to depend on Wintab? Works great on my T901, no pen pressure available and major jitter on my GB10. :(
    Fluffyfurball likes this.
  2. DRTigerlilly
    7,524
    703
    301
    It will clearly depend on your usage scenario, but for simply notetaking/inking not sure how necessary pen pressure is.
  3. Selofain
    538
    305
    If I'm using a pen, I expect pen pressure, simple as that. Doesn't matter what I'm doing. I can vary line thickness with any analog pen/pencil I use, therefore any digital pen I use will behave the same. If it doesn't, it's not worth my time.
  4. djas
    djas Graffiti User
    638
    511
    PDF Annotator was very good on my old retired TC1100 but as others here mentioned, the price was high. This really brings home the difference between a proper software and an app? I think so.
    Squid (formerly Papyrus) is a cross platform Android and UWP app that can import PDF files. It works very well and is vector-based. Gotta pay for the PDF functionality though.
    Alternatively, there is Windows Journal? I used to import and then annotate PDFs onto Journal. Worked very well.
    The majority of my PDF-related workflow are done on my GTA8SP though; via Write-on-PDF, SNote and LectureNotes. The Wacom EMR, imho, is still the premier active digitizer/pen solution. This is coming from someone who has been paperless and early Tablet PC adoptor since 2004. YMMV.
    Fluffyfurball and WillAdams like this.
  5. Fluffyfurball
    Fluffyfurball Scribbler - Standard Member
    209
    55
    Wow. Didn't know that one. Thanks for the head's up.
  6. doobiedoobiedum
    914
    345
    There isn't an import command in Journal and it doesn't see anything except .jnt or .jtp so I'd be curious how you imported .pdfs into Journal?
  7. WillAdams
    978
    422
    You print the PDF using the Journal printer driver which makes it into a .jnt.
  8. doobiedoobiedum
    914
    345
    Thanks Will - I may be missing something but that's exporting a pdf. I can do that and have done before. "djas" however said he could import and annotate a pdf in Journal and that's the bit I'd like to do. Would save me at least 4 steps in a pipeline sequence I sometimes use to create artwork.
  9. ATIVQ
    ATIVQ V⅁O⅄ Senior Member
    1,003
    570
    Like everybody said, Xodo. Free, lots of features. They need to fix the interface so it's not so clunky (switching between scrolling and inking is ridiculously menu-intensive!) and they need to provide built-in templates like Penbook. That would make it perfect.
    WillAdams likes this.
  10. djas
    djas Graffiti User
    638
    511
    As per @WillAdams said.
    However, I just use MS Edge to annotate PDFs nowadays.
