Best iPad Stylus?
Discussion in 'Apple/iOS' started by ghb2009, Sep 6, 2010.
  1. Nichod
    Nichod Scribbler - Standard Member
    147
    I think the "best" actually is the new Wacom. I've tried it myself and it rolls across the screen smoothly compared to the other options.
  2. sketchyd
    sketchyd Pen Pal - Newbie
    51
  3. vap3
    vap3 Pen Pal - Newbie
    86
  4. JaneL
    JaneL Super Moderator Super Moderator
    246
    22
    I'm using Wacom's Bamboo stylus, and it works pretty well for me.
  5. ethansamuel17
    ethansamuel17 Pen Pal - Newbie
    Till date I used pogo, amazon and boxwave. For me amazon and boxwave is very much comfortable and more effective then rest.
  6. DaveOnBass
    DaveOnBass Scribbler - Standard Member
    152
    While I didn't end up keeping the iPad I just bought, I have to put out there that for accuracy, the Adonit Jot is an AWESOME stylus. I was able to draw quite accurately in Sketchbook with it - the metal ball-tip-and-crosshair seems to concentrate the touch point very well, and the clear plastic disc that makes up the whole tip lets you see where you're placing your lines very nicely. For drawing, I can't recommend any other.
  7. jagger
    jagger Pen Pal - Newbie
    not a fan of stylus. prefers to use fingers. fingers would do the job smoothly if you have a matte finish screen protector. your reaction while holding a stylus for playing games and browsing are slower compared to using your finger
  8. bloodycape
    bloodycape Scribbler - Standard Member Senior Member
    2,288
    205
    Maybe for those task, but for drawing, writing a stylus is better and depending on the stylus a little more accurate.
  9. jemyclarke
    jemyclarke Pen Pal - Newbie
    32
    I am all for the TruGlide stylus sold by Lynktec! It's a fantastic product and it is very flexible to use. Really like that it has a microfiber tip, instead of the usual rubber or foam tips.
