Battery Life T5010
Discussion in 'Fujitsu' started by aretzios, Dec 26, 2008.
  1. ProgressionMurph
    ProgressionMurph Pen Pal - Newbie
    52
    Whats the longest anyone has had the T5010 running for with regular battery?
    Also what about when the modular battery is in?
    and everything clocked down?
    And, how do you charge the modular battery? just have it in when you plug the Tablet in?
  2. Dynafrom
    Dynafrom Pen Pal - Newbie
    55
    With regular on balanced about 4~ hours. With modular, around 7-9 hours depending on what I do. With everything turned ALL the way down w/ modular at least 11hrs.
  3. ProgressionMurph
    52
    Lovely. Much appreciated!
  4. Grimnir
    758
    You can only charge the modular bay battery when it is in the modular bay and the tablet is plugged in.
  5. lowlife
    lowlife Addicted to gadgets
    99
    With modular battery, connectivity turned off (usb connected phone for internet), and Powersaver I get 7 - 8 hrs. running 2.53 version w/ 4 gigs.
  6. overfiend06
    overfiend06 Pen Pal - Newbie
    90
    What is the weight of the modular battery? I'm trying to figure out how much weight would be added in addition to the weight of the tablet.
    I've looked everywhere for this spec, even in the manual and could not find it...??
  7. Grimnir
    758
    its really not heavy at all..I don't have a scale handy but I'd estimate it is about a half of a pound at most.
  8. overfiend06
    90
    Cool!! I just read your review and you stated the tablet + modular is about 5.2 pounds. :D
  9. Grimnir
    758
    Exactly. It is 5.2 lbs, and it is very well balanced. So it really is no trouble at all to hold for an extended period of time.
  10. aretzios
    aretzios Scribbler - Standard Member
    182
    Well, the modular battery is heavier than the DVD-writer, that's for sure. How much heavier? Probably a quater of a pound. My experience with the time one gets on battery plus modular battery is the same as that of the others: about 8 hours with with good amount of hard disk use.
