AutoWallpaper - Change wallpaper after rotation
Discussion in 'Software' started by dangsquall, Nov 29, 2010.
  1. dangsquall
    dangsquall Pen Pal - Newbie
    Hi everyone,
    I wrote a little program called AutoWallpaper that automatically changes your wallpaper when Windows detects a change in rotation. It's very simple at the moment: choose your wallpaper for horizontal and vertical modes, and choose your wallpaper styles. You can request more features in this thread if you want to :D
    If you use Rainmeter, RainRez does the same thing, but I don't use Rainmeter, so I created something small so as not to affect the battery life.
    Most recent version can be downloaded at: Free File Hosting Made Simple - MediaFire
  2. Agent 9
    5,376
    many thanks for this!!!:) :) :)
    I have the HP Tm2 (with a small auto rotate application as well) and so far it has worked perfectly.
    I've been looking for a small light application to do exactly this for some time now. Thanks!!!
    I'll tell you if anything needs to be changed or fixed.
    Thanks again!!!
  3. dangsquall
    Hey, thanks for the reply. I'm using a Tm2t myself, but at least now I'm relieved it works on someone else's system :D
    Now if only someone with a different laptop has tried the program...
  4. Agent 9
    5,376
    It is still working great, I have confirmed it works perfectly even with a multi-monitor setup.
    Again, thanks!!!
    +1 (anyone else using this should do the same)
