ATIV SMART PC Tips & Tricks
Discussion in 'Samsung' started by kontrol1, Nov 20, 2012.
  1. Inkermoy
    Inkermoy Scribbler - Standard Member
    213
    Maybe the New Thread button on the main Samsung page? ;P
    To get to the mics anyways, I found both the mic and the camera for my ATIV and S7S to be... Crap. I had better audio recording a live band on my point and shoot camera than I did with my tablet (ran out of battery on my camera). No matter how many Megapixels you have, doesn't substitute for crap hardware. External mic would probably do better.
  2. Turps
    Turps Pen Pal - Newbie
    Thanks for the advice, will look a bit further into another option maybe, thanks again.
  3. Rommie2k6
    Rommie2k6 Scribbler - Standard Member
    378
    How does one enter BIOS? I don't have the keyboard dock
  4. manu72
    manu72 Pen Pal - Newbie
    Press the Windows button during startup. At least that's how it works for Ativ Smart PC Pro (700t1c)
  5. bemymonkey
    bemymonkey Scribbler - Standard Member
    121
    Actually I think I remember it being the volume down button on the Non-Pro... might as well try both though :p
  6. KBJ911
    KBJ911 Pen Pal - Newbie
    calling mini snote :
    just move your hand over screen from left to right
    700T
  7. aussiedeza
    aussiedeza Scribbler - Standard Member
    144
    dam all the drivers are unavailable on the site , i need the graphics driver too fix this screen brightness issue.... anyone have it?
  8. tablet1425
    tablet1425 Pen Pal - Newbie
    It's big. It won't fit into a pocketbook or pocket - if you want to tote it around you will probably want some kind of a cover or netbook bag for it.
  9. moorken
    moorken Pen Pal - Newbie
    i would like to know this to, because in the past i once had a Sony Vaio which i couldn't reinstall anymore because it detected a modified system, so my installation disk couldn't be used anymore. i'm not touching my Ativ anymore without being sure on this!
    Android Wallpaper Central
  10. MysticVenator
    MysticVenator Pen Pal - Newbie
    I know this is an old thread but wanted to say you can use a Fujitsu stylus with the Wacom driver to get 2-button stylus support. Here's the Amazon link for the 2pk (no I'm not affliated with either Amazon or Fujitsu):
    FUJITSU Stylus 2pk FPCPN28AP
