ATIV SMART PC Tips & Tricks
Discussion in 'Samsung' started by kontrol1, Nov 20, 2012.
  1. kontrol1
    kontrol1 Scribbler - Standard Member
    151
    21
    Please PM me if something is worth adding to the sticky
    1)Driver update to fix hibernation issues: Post # 302
    http://forum.tabletpcreview.com/samsung/53549-i-just-picked-up-ativ-smart-pc-500t-staples-review-purposes-31.html
    2)Screenshots on SMART PC:
    http://forum.tabletpcreview.com/samsung/53862-screenshots-smartpc.html
    3)Updating BIOS: Post 351,353
    http://forum.tabletpcreview.com/samsung/53549-i-just-picked-up-ativ-smart-pc-500t-staples-review-purposes-36.html
    4)Drivers,Software and Firmware/BIOS
    http://www.samsung.com/us/support/owners/product/XE500T1C-A01US
    5)Touch On/Off toggle
    http://forum.tabletpcreview.com/samsung/53635-touch-off-toggle-ativ-smart-pc-500t.html
    6) Two ways to reset the device(post # 3)
    http://forum.tabletpcreview.com/samsung/53880-smart-pc-freezes-other-problems.html
    7)Model differences (non-conclusive)
    http://forum.tabletpcreview.com/samsung/53961-samsung-ativ-smart-pc-model-difference-features.html
    8)Boot from USB(post # 2)
    http://forum.tabletpcreview.com/samsung/53946-boot-usb-500t.html
    9)Accessing BIOS( User Manual page 94)
    " 1 Shut the computer down.
    2 Press the computer’s Power button.If the Samsung logo screen appears, press the Home button
    3 After a moment, the BIOS setup screen appears. The items in the BIOS setup may differ depending on the product."
    4) Another method (press f2 immediately after pressing the power button)
    10)Workaround for "Hibernate gone or changed since last bios update" (post # 17)
    http://forum.tabletpcreview.com/sam...ne-changed-since-last-bios-update-500t-2.html
    11)Calibrating screen with more points(post # 9)
    http://forum.tabletpcreview.com/samsung/54222-any-program-reduces-screen-size-just-get-rid-edge-stylus-problems.html
    12)Advanced restart menu
    Press vol up+power button from shutdown. Keep holding until the choose your keyboard layout screen pos up. Pick kb layout>troubleshoot>pick desired option
    13) [Verified] Clean install Windows 8 into your ATIV Smart PC 500T.(Thx amdhunter)
    http://forum.tabletpcreview.com/samsung/54631-clean-install-windows-into-your-ativ-smart-pc-500t.html
    14)Re:How to integrate Windows Updates and Drivers in your Windows 8 installation USB Flash media.
    http://forum.tabletpcreview.com/samsung/54631-clean-install-windows-into-your-ativ-smart-pc-500t-3.html#post309684
    15)Disable Lock screen on wake(Thx Inkermoy)
    http://www.bleepingcomputer.com/tutorials/disable-lock-screen-in-windows-8/#registry
    16)How to get rid of "Samsung Software" on XE500T? (post # 3)
    http://forum.tabletpcreview.com/samsung/54857-how-get-rid-samsung-software-xe500t.html#post307558
    Accessories:
    http://www.samsung.com/us/computer/tablet-pcs/XE500T1C-A03US-accessories
    http://www.amazon.com/s/ref=nb_sb_ss_i_0_24?url=search-alias%3Delectronics&field-keywords=ativ+smart+pc+screen+protector&sprefix=ativ+smart+pc+screen+pro%2Celectronics%2C220&rh=n%3A172282%2Ck%3Aativ+smart+pc+screen+protector
    http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Delectronics&field-keywords=ativ+smart+pc+case&rh=n%3A172282%2Ck%3Aativ+smart+pc+case
    http://www.amazon.com/Samsung-Electronics-Digitizer-AA-DP2N65L-US/dp/B009TOY2J8/ref=sr_1_7?s=electronics&ie=UTF8&qid=1356820354&sr=1-7&keywords=ativ+smart+pc+pen
    Detailed eviews & User reviews.
    http://www.neowin.net/forum/topic/1120372-samsung-smart-pc-windows-8-atom-tablet-review/
    http://www.umpcportal.com/2012/11/review-samsung-ativ-smart-pc-500t/
    http://gizmodo.com/smart-pc/
    http://forum.xda-developers.com/showthread.php?t=1957857
    http://forum.tabletpcreview.com/samsung/54206-students-review-opinion-ativ-500t-slate.html
    http://www.amazon.com/Samsung-ATIV-Smart-PC-500T/dp/B0098O9TB0/ref=sr_1_1?ie=UTF8&qid=1354474197&sr=8-1&keywords=ativ+smart+pc
    http://www.tomshardware.com/reviews/ativ-smart-pc-500t-windows-8-atom,3360.html
    NYBY15, wilfrid10 and thierryb like this.
  2. e-schreiber
    2,629
    59
    I almost suggested that yesterday. It was high time someone started a New Users Guide for the Ativ!
    Repped! :)
  3. Steve S
    7,603
    3,110
    <<...Please sticky this...>>
    ...Done.
  4. drunkirishman
    drunkirishman Pen Pal - Newbie
  5. redgeek
    redgeek Pen Pal - Newbie
    Missing the URL for the touch on/off toggle.... but thanks for posting this!
  6. Osiris
    Osiris Scribbler - Standard Member
    293
    35
  7. kontrol1
    151
    21
    Fixed Touch on/off URL. Added 2 ways to reset device link.
  8. JoeS
    4,829
    2,887
    I'd be interested in some info on which pieces of cr_pware are considered tolerable. I got rid of Norton and all Samsung Metro apps, but I still have the following:
    - E-POP
    - SW Update
    - Settings
    - Touch supporter
    - Support center
    - User guide
    - Help desk
    So far I'm thinking of only keeping SW Update, but maybe you guys have found some use for the other components?
  9. User Retired
    User Retired Pen Pal - Newbie
    Has anyone opened the Ativ Pro 700t and been able to put it back together correctly as I would like to upgrade the SSD to 256GB mSATA? It is not like the previous Series 7 from what I can tell in other disassemble threads. Thank you in advance for any help.
  10. sudermatt
    sudermatt Scribbler - Standard Member
    345
    Migh I suggest an Accessories section to this post....cases, working styli, etc.
