Atheros Vs. Centrino-Branded
Discussion in 'Fujitsu' started by TabletMaster, Jul 6, 2006.
  1. TabletMaster
    TabletMaster Pen Pal - Newbie
    Hi all,
    I'm buying a Fujitsu T4210 and had a question about the wireless radio. My question is: Which should I get, the Atheros card or the Intel card? Now I know the whole schtick with the Centrino marketing campaign and how it's simply the bundling of the processor, chipset and wireless card from Intel, but I'm interested in real-world performance and battery-life testing of both wireless cards. I'm especially concerned about battery life; I know Intel insinuates in some of its marketing literature that the Centrino platform provides better battery life, but as far as I can discern this is only due to the processor and chipset, and not the wireless card. Some have said that the Intel wireless card can take advantage of "special Centrino extensions in the processor" to save battery life; with everything I know about the platform, I tend to be skeptical of this claim, but can anyone with definitive knowledge confirm or deny this? However, I'm mostly interested in real-world battery life results. Can anyone who has used both cards in the same model laptop comment on a comparison of battery life between the two cards? Also, can you comment on performance (but I'm mostly interested in battery life)? I've read that the Atheros card performs better and more reliably than the Intel card. Is there any truth to that? Any comments from Barry or Brian would be especially appreciated. Thanks so much.
    Jonathan
  2. Barry J. Doyle
    2,153
    Jonathan,
    Both Brian and I would agree that the Atheros is just simply a better card. Any battery life differences between the Atheros card and the Intel Pro Wireless would be negligible. The Atheros configuration software is a bit more advanced than the the Intel Pro Wireless setup, but without a doubt I would go with the Atheros option. These cards simply offer a stronger and more reliable connection overall. I hope that helps!
    Barry
  3. TabletMaster
    That was very helpful. Thank you very much!
    Jonathan
  4. Brian
    1,305
    I concur. Been using Fujitsu for about three years, go with the D trim every time.
  5. PYROTAK
    286
    yeah i have noticed that my centrino wifi does drop a lot, can't comment on its comparison to arthros though.
  6. Loaf.
    137
    the only question is if it's worth it, because the centrino based ones at newegg are low $1700s while a similarly configured atheros version is about $100 more from fujitsu.
  7. Brian
    1,305
    That's a valid point of course. It's hard to put a value on it, but $100 is probably too much of a premium. If you get the Intel card though, I'd definitely remove their wireless management app, you're better off with the Windows zero config.
  8. PYROTAK
    286
    I always use the windows zero config...is the arthos wireless mangager superior to that of windows or something?
Similar Threads - Atheros Centrino Branded
  1. ATIVQ
    385
