asus vivotab note 8 USB broken? Here's how to fix.
Discussion in 'Asus' started by darkblu12, Oct 13, 2014.
  1. Bronsky
    8,076
    4,932
    Wow! Just saw the updated thread. Great job on the repairs. The ability to easily replace the USB port is an incredible plus for this device. Do you think this thread could be stickied too?
  2. 2.0™
    2.0™ Been Inkin' Staff Member
    394
    87
    Stickied and renamed. :)
    thierryb and Bronsky like this.
  3. Sandiegosd
    Sandiegosd Pen Pal - Newbie
    82
    How often does this problem occur? I'm prepared for the touchscreen/digitizer freezing up but replacing USB port so it can charge is a bit too much
  4. Sweetpea8472
    Sweetpea8472 Scribbler - Standard Member
    447
    116
    I've not had any problem with my USB port, nor has the second unit in our house.
  5. Mesosphere
    5,313
    2,060
    I've heard of these few cases of it breaking and one other case where it got bent (and some pliers fixed it)... so not very often.
    This isn't really a problem with the tablet, any tablet is vulnerable to physical damage. Micro usb ports are fragile by nature. You should be careful with it. The Dell Venue 8 Pro seemed to have a lot more problems with broken USB ports (at least early on, I haven't kept up with it), but that could just be a larger user base.
  6. 2.0™
    394
    87
  7. graki
    graki Pen Pal - Newbie
    35
    Hi atranzy,
    You got my eternal gratitude : your description of the part and the process to replace it helped me to revive my "dead" M80TA, this was just this damn broken usb port, I'm very happy.
    As a side note the camera connector on the usb mini-board got a white vertical "clipper" one should push 90° wise on the board to fasten the connection (figured this after 20 minutes of struggle about why I lost the front camera...)
    Regards
    thierryb likes this.
  8. LeanLee
    LeanLee Pen Pal - Newbie
    29
    Pics are no longer available.
  9. riukas
    riukas Pen Pal - Newbie
    Hi, can someone help me with the USB PCB problem (which probably made even more problems in other tablet parts) in this post please?
  10. scirocco
    scirocco Pen Pal - Newbie
    My USB (and touch screen) have been flaky for awhile. I am finally getting around to the DIY repair, but this thread is pretty old, and some of the pics have been lost to time, so I am wondering what the best options are now. It seems like the original repair described in this thread replaced the entire board that the micro USB port was attached to which still costs around $46, shipped from the UK? Is there a better source (cheaper, or in the US)? Am I just setting myself up for a similar repair in the future since I am just swapping in a stock part which obviously have some higher than normal failure rate on the micro USB port? It looks like I could get just the port from ebay for around $6 and would just have to solder the old one off and replace, which I would feel comfortable doing based on the pics I have seen. Is this not a viable option? Just trying to get some feedback from someone who might have done this fix recently so I can budget for this and the screen repair... Thanks.
    riukas likes this.
Similar Threads - asus vivotab note
  1. JoeS
    200
  2. Mr. Boosh
    1,199
  3. daddyfish
    573
