Asus VivoTab Note 8 Tips & Tricks
Discussion in 'Asus' started by dstrauss, Feb 27, 2014.
  1. Supraman321
    Supraman321 Pen Pal - Newbie
    Does anyone know how to get in to the BIOS on the Note 8? Been struggling with trying to get in there :(.....
  2. legolas93
    legolas93 Pen Pal - Newbie
    Yes.
    Link: Here :)
  3. vvilmos
    vvilmos Pen Pal - Newbie
    I flashed the 209 bios firmware and still cannot enter directly in Bios by pressing
    simultaneously "Power" and "Vol-" when the tablet is off.
    Any idea why?
  4. Supraman321
    Dang, I have to update the BIOS to get in to it, I guess I'm screwed then as someone tried to install an x64 OS and it won't load past an error screen saying it isn't supported and so I can't really update the BIOS in the OS :(.
  5. surt
    surt Pen Pal - Newbie
    21
    Something I just discovered:
    My Studio Pen Pro has always given me ghost clicks in the bottom left corner.
    After removing the included stylus no more ghost clicks.
  6. justpick1
    justpick1 Pen Pal - Newbie
    50
    22
    Very interesting.
    I don't know what one thing has to do with the other, but I've always noticed that the activation range (i.e. when detected in hovering) for the pen is quite long; almost twice that of the Ativ 500t. Also, and this is most apparent on web pages, there is often an activity circle instead of a dot when I first pull out the pen to do something onscreen. As if it's constantly engaged in carrying out some action.
  7. bellmano
    bellmano Pen Pal - Newbie
    Maybe this have been mentioned before: i you don't restart (cold start) your note 8, but only use sleep mode then you could turn hibernation off and save some space. With hibernation turned on i had 8.3gb free, with hibernation turned off i have 11.3gb free.
    to turn hibernation off use this text in an elevated command: powercfg /h off
    Crowfeather likes this.
  8. alins
    alins Pen Pal - Newbie
    I wrote to Pluggable about this and here is their reply:
    Connecting Asus Vivotab Note 8 (M80TA) to VGA port of projector
    Josh, Jul 05 14:16
    Hello,
    Thank you for contacting Plugable support! I'd be more than happy to assist you with this issue.
    Yes the UGA-165 will work with your tablet if you use an OTG cable.
    Unfortunately there is not a solution for charging for your tablet.
    Please don't hesitate to let us know of other questions.
    Thanks again for contacting Plugable support and best wishes!
    Plugable Technologies
  9. leomon32
    leomon32 Pen Pal - Newbie
    Some tips for artist that got problem with software like Sai Painting (you palm will move the whole artwork)
    - You can use a wacom tablet plug into your AVN8 with an otg, but you will notice that you will have ripple effects, it's because by default, Windows Ink is activated with the Wacom Tablet (plugged or not). If you lost pressure after installing the drivers, just discard all the Wacom preferences and it will work (you will find it on the start menu, start8 is your friend here ;3 )
    - Disable the touch screen on the material will make your tablet "pen only" which is awesome to draw of course ! I was stupid not thinking about it before...
  10. bluedingo
    bluedingo Pen Pal - Newbie
    How do I do that?
Similar Threads - Asus VivoTab Note
  1. Luca92
    5,101
