Asus VivoTab Note 8 Tips & Tricks
Discussion in 'Asus' started by dstrauss, Feb 27, 2014.
  1. agraham
    agraham Pen Pal - Newbie
    34
    Apparently InstantGo/Connected Standby tablets won't hibernate as standard! They can be made to do so but be aware that doing so creates hiberfil.sys and wastes what could be precious disk space.
    To enable hibernate open a Command Prompt as Administrator, type "powercfg -h on" and then press Enter.
    You can set Power options -> Hibernate on Power button and lid close or you can make a shortcut to Hibernate on the desktop
    Target - %windir%\System32\rundll32.exe powrprof.dll,SetSuspendState Hibernate
    Start in - %windir%
    To disable Hibernate and delele hyberfil.sys then type "powercfg -h off" at a Adiminstrator Command Prompt.
  2. flaneige
    flaneige Pen Pal - Newbie
    Thanks, the shortcut works perfectly
  3. HdNote8
    HdNote8 creative technical writing
    70
    took me an age to find this post again after acquiring my note8 / 64, thank you
  4. Kumabjorn
    4,316
    2,381
    You're welcome. You can set it up to use OneDrive do the notes are synced between your devices.
  5. HJK
    588
    72
    I knew of the app ages ago but would have had no use for it on a laptop, so I had long since forgotten about it. If this is on Win 10 it could be cool to use in tablet mode.
    How do you configure it to sync via OneDrive?
  6. Kumabjorn
    4,316
    2,381
    I just asked Cortana to do it, but I had to ask very politely before she changed the settings.
  7. HdNote8
    70
    spill the beans !
  8. Kumabjorn
    4,316
    2,381
    Only Cortana can do that.
  9. HJK
    588
    72
    I suppose that is one reason to upgrade to Windows 10.
  10. Mr. Boosh
    Mr. Boosh Scribbler - Standard Member Senior Member
    845
    299
    Not working for me, for some reason. Elevated command prompt seems to register though.
Similar Threads - Asus VivoTab Note
  1. Luca92
    3,578
  2. Mark C
    718
