Asus VivoTab Note 8 - Reviews
Discussion in 'Asus' started by PECgem, Jan 7, 2014.
  1. llatnik
    llatnik Pen Pal - Newbie
    24
    appears on phone results for me too, linked my pc from my phone because derp amazon.
    now on wishlist, cheers
  2. Avenger
    Avenger Scribbler - Standard Member
    123
    Quote: (Here's my first inking effort on the Asus Vivotab Note 8 with Clip Studio Paint. I'm using a Surface Pro pen because I find its nib offers the most consistent results on the tablet screen's coating..)
    Interesting comment regarding the surface pro pen. The surface of the tablet seems a little different from other tablets. The feel of the included pen against it is a bit rough and inconsistent. I may try the surface pro pen if the feel is better. Otherwise I guess I could try a screen protector when they come on the market.
  3. Mesosphere
    5,313
    2,060
    The adapter does work with type cover 1. That is the one I use it on.
  4. Kumabjorn
    4,430
    2,602
    If your aim is to digitize handwriting, a cheaper and more reliable method is to use a Galaxy Note from Samsung. You should be able to get an older model for very little money. The standard keyboard takes handwriting with the stylus and turns it into digital text, if you use it with one of the Office compatible suites, Samsung bundles Polaris Office, then you will have a Word compatible file. There are three available form factors available, the phone in landscape mode is very comfortable and you can write anywhere with that. You might want to invest in a more pen like stylus from Wacom or Samsung.
    Sent from my GT-N5110 using Tapatalk 4
  5. surfaceproartist
    2,930
    1,893
    Same here. There are various areas on the display that feel gritty under the standard stylus; much less so with other pens.
  6. Mesosphere
    5,313
    2,060
    Handwritting recognition is build into the tablet input panel. So you can enter text into any field or program that way just like you would with the touch keyboard. The handwritting recognition works well a lot of the time. I find it frustrating to correct mistakes with though. It is a lot like voice regognition in that it translates the words not the letters. So like with voice recognition when you try to input a word that is somewhat unusual, but sounds a lot like a common word it will insist on using the common word no matter how many times you repeat it. Alternatively there is an input mode where it converts letter by letter, but then the recognition is generally less reliable (except in the case I mentioned).
    There is also the option in programs like onenote to select a section of handwriting and convert it to text. I don't think there is an option within onenote for it to convert to text as you write it though.
    If your wifes usual method is writing then typing. I think even with the quirks though it may save her time. Probably the best way is entering it in one note then converting it to text. Then go back and fix the mistakes. This might be faster than writing and then typing the whole thing in. A good thing about the low price point is it is less risky to take a chance on it and see if it works for you.
  7. Bibble
    Bibble Pen Pal - Newbie
    Mine just arrived but I don't seem to have the recovery micro SD? What brand should the card be anyone else who has one?
  8. spinedoc77
    1,871
    464
    No I understand that, I think we are just talking about 2 different things. My concern isn't a 2nd /external display, it's the way the UI elements are scaled on the tablet screen itself.
  9. mpattman
    mpattman Pen Pal - Newbie
    35
    Is yours a 32GB or 64GB version? Only the 32GB versions come with the recovery on a microSD card.
    Please do, that sounds interesting.
  10. surfaceproartist
    2,930
    1,893
    On my 32GB, the microSD is Asus branded. It shows up as D:\ in the file explorer.
