Asus VivoTab Note 8 - Reviews
Discussion in 'Asus' started by PECgem, Jan 7, 2014.
  1. jaylj14
    jaylj14 Pen Pal - Newbie
    Well, IMO, I think it might work. I'm now waiting AVN8 to be available in Taiwan.
    I'm using Miix2 8" right now and it works fine to charge and OTG simultaneously just using a Y-cable(purchased from China).
    »ªË¶ME400C OTG Êý¾ÝÏß ³äµçÏß ÍêÃÀʵÏÖͬʱ³äµçºÍ´«ÊäÊý¾Ý YÏß-ÌÔ±¦Íø
    This cable is originally made for ASUS memopad. I think AVN8 will be able to charge and OTG at the same time by using the simplest Y-OTG-Cable.
    Or you can try using a Lenovo's charger which provides a slightly higher Voltage (5.2V 2A).
    I noticed that DV8P won't work with the Y-cable, which might be the reason for the +port showing up on Kickstarter.
  2. Zeelobby
    Zeelobby Scribbler - Standard Member Senior Member
    1,230
    202
    I would hope not considering Asus makes it ;)
    Sent from my XT1060 using Tapatalk
    Mesosphere and Rodney like this.
  3. inmnbob
    inmnbob Scribbler - Standard Member
    202
    48
    Good catch...that was the first laugh of the day
    Sent from my SM-N900P using Tapatalk
    Bronsky and Zeelobby like this.
  4. Mesosphere
    5,313
    2,060
    Unfortunately, it has already been confirmed a simple y-cable will not work. It definitely requires some sort of hack to get data and charging at the same time, and it seems to be a different mechanism than on the Dell. The Miix 8 is the odd one out. Its the only one of the bunch that allows simultaneous charging/data.
    http://forum.tabletpcreview.com/asus/61085-asus-vivotab-note-8-charging-usb-otg-same-time.html
  5. lovelaptops
    2,559
    1,062
    Are you sure you're a "real" lawyer? I've never met one that didn't think he knew everything! :D
  6. soh5
    soh5 Wait and Hope (Bronsky et al.) Senior Member
    1,365
    695
    For me the tracking works fine all around the screen, but towards the top right and middle edge (when viewed in portrait mode), have issues with input.
    These areas when I scribe in one note or any other inking program, makes everything look fuzzy and grainy. It looks like a first grader wrote it, but moving about 1 inch away from the edge my hand writing looks great just like the surface pro. Kinda annoying...
  7. SuperiorWitt
    SuperiorWitt Pen Pal - Newbie
    42
    For those in my area, Pentagon City has 3 64gbs left in stock. Just picked one up.
    dstrauss likes this.
  8. dstrauss
    10,725
    9,261
    I think Meso aready covered this, but a Y Cable just won't cut it.
    I am and I do - I just don't flaunt it....:cool:
    Bronsky, Mesosphere and lonaysta like this.
  9. Mesosphere
    5,313
    2,060
    Since you are there (Tiawan), you could go give Jonney a visit and ask for him to patch it for us =)
  10. SAM 2013
    859
    221
    D#@* It Jim, he's a Lawyer, not a Doctor!!!
    dstrauss and Bronsky like this.
Similar Threads - Asus VivoTab Note
  1. JoeS
    214
  2. Mr. Boosh
    1,393
  3. daddyfish
    594
