Asus VivoTab Note 8 - Reviews
Discussion in 'Asus' started by PECgem, Jan 7, 2014.
  1. Waru
    Waru 「ホログラム&#
    128
    52
    Gosh, this is so much fun. This thing is my new buddy, seriously.
  2. Mac jones
    Mac jones Scribbler - Standard Member
    183
    48
    Yikes, nice pen (and GREAT art)
    That pen is definitely too good for me ;)
    But for drawing, the tablets are probably great. They are so light you can hold them in close for extended periods for more detail. Of course you zoom for that.
    Waru likes this.
  3. Mesosphere
    5,313
    2,060
    Finally my F5 resulted in an update. My tablet arrived in Chicago (Hodgkins) at 5:42 this morning. It is only 600 miles away. It is still showing a Wednesday delivery though. I don't think I will receive it early at this point. And the rain just turned to snow a couple minutes ago, so it may even be late. I should have clicked instant =)
  4. Bronsky
    8,121
    4,992
    Mine is still in transit and showing "on-time" delivery. The storm shifted, however, and we already have a couple of inches on the ground. Crossing my fingers.
    Very nice work. If you can do that with the M80T, it will be fine for my pedestrian uses. Did you do that with the cover on and flipped backward? If so, it doesn't look like your cover is interfering with your pen.;)
    Waru likes this.
  5. Stavros
    Stavros Pen Pal - Newbie
    40
    To sszz:
    'However the recovery image location seems to be empty suggesting the system has no idea where to look for the recovery image. If you type "recovery" to the Win8.1 search box then choose "Create a recovery drive", is the "Copy the recovery partition from the PC to the recovery drive." checkbox available or greyed out?'
    Yes, it is.
    'I would also like to know what is in the Sources folder, is it just the install.wim or is there something else?'
    Yes, just install.wim
    'Furthermore, would you mind to PM me the Autorun.inf, Recoverymedia.xml SD Card.ico and ***.txt files for further analysis?'
    How do I send files in a PM?
    sszz likes this.
  6. reg21
    reg21 Pen Pal - Newbie
    Guys, is normal to get about 3h with intensive use of the tablet? I'm saying about gaming and something like that. Besides, while i'm charging and using the tablet is ridiculous the charging rate and also if you continue with the intensive use, it continues discharging :S
    Thanks!
  7. cmenice
    cmenice Scribbler - Standard Member
    556
    40
    I'm just curious, does anyone know why there is a price discrepancy between the online price ($329) vs. the instore price ($299) for the 32gb? I'm kind of lazy and don't feel like going to the store, but I might have to to save the $30.
  8. Mesosphere
    5,313
    2,060
    3h is a reasonable number. That implies 5W of power draw. My Venue 8 Pro draws about 3W in light use just from having max screen brightness. Also the charge time for the tablet is supposed to be 3h, so it charges at 5W, and you are using 5W, so it may continue to discharge (at a very slow rate) if pushing it as hard as you are.
    Edit: It seems Intel doesn't publish TDP for Bay Trail only SDP of 2W; however, some have speculated that the TDP is ~4W, so, if that is correct, 5W seems pretty much in line with expectations when you add in the screen power usage.
  9. sszz
    sszz Pen Pal - Newbie
    42
    Hmm, then I don't understand... Mistery.
    You might be right, that's not that easy. I sent you a PM with my email, you can simply send there...
    Thanks again.
  10. bvretr
    bvretr Pen Pal - Newbie
    22
