Asus Vivotab Note 8 Pen failure rate
Discussion in 'Asus' started by Mesosphere, Apr 22, 2014.
  1. Bronsky
    7,682
    4,143
    Microsoft Store is having small business week from the 12th to the 16th. I think it would be a good time to take my Asus back.:D
  2. solitaire01
    solitaire01 Pen Pal - Newbie
    65
    Ok, I'm feeling pretty confident in this fix - it fits the MO of the I2C-related errors I've seen and the documentation of how this HID driver system enumerates the BIOS. And the results took me from constant issues to no issues without a single OS change.
    Basically, reflash your BIOS to 206 if you're on 207. To downgrade the BIOS you need to run winflash.exe from a command prompt with the argument "/nodate". Winflash and the 206 BIOS are available on the Asus support downloads page for the M80TA.
    Firmware downgrades carry risk which is why I was hesitant to suggest it until I reached a degree of confidence that this could be the fix. I look forward to others' results - if you have the same outcome it's likely the issue is a buggy BIOS that may have corrupted during system restarts. It could explain how such an obvious issue escaped QA, if older BIOS versions don't have the bug.
    That said, my worry is that in 30 days the issue returns which could point to a deeper issue with the BIOS. But I will hold out hope.
    Good luck!
    thierryb likes this.
  3. dstrauss
    9,742
    7,716
    Doug - sure hope you are right. It really looks plausible.
  4. thierryb
    1,379
    291
    I will try. Because effectively, its look plausible.
    And because mine is really died.
    So if it will revive, I will really congratulate you.
    But why some have and other not ?
  5. SAM 2013
    859
    221
    Did the first units have the 206 Bios?
    I never updated my bios on my 32gb original.
    Where do you tell what version your on?
  6. squib
    squib Pen Pal - Newbie
    85
    It's under system information.
  7. thierryb
    1,379
    291
    My first M80TA, which has always a non working digitizer, is under 206 bios. I tried to upgrade it to version 207 without any success. I have a message telling that it cannot allocate memory for the bios upgrade.
    My second M80TA, which is always with a working digitizer and no other related issues (orientation), is under 207 bios.
    @solitaire, Which was your original bios before your upgrade, 206 or 207 ?
    @Sam, to have your bios version, start the flash tool, give it a bios image, and it will tell you which bios you have, and if you want to do the upgrade, if the bios you give him is more recent. But you can stop at this stage. No risk.
  8. alexb2611
    alexb2611 Pen Pal - Newbie
    59
    My 2014/01 build date replacement (always working) unit is 206 bios, I got the original one quite soon after they were released in the UK, it was also 2014/01 build date, so I think safe to assume that was 206 bios too. That one failed after a week.
  9. solitaire01
    65
    Hi all - my 64gb shipped with 207. Based on comments I'm not convinced a specific bios date will fix it, but I am curious if a bios flash to any version, will at least temporarily stop the symptoms. If so it suggests the issue may lie in this area.
    Cheers!
  10. solitaire01
    65
    Well, 24 hours after backleveling to 206 the pen disappeared again. I went back to 207 and it came back. Tonight the device failed with error code 10 and I couldn't get it to work at all after reboots -- but then I flashed 207 on top of 207. And guess what? Pen came back. I'm basically convinced it's a BIOS issue, but one without a solution as of yet. At least I know I can kickstart it by reflashing. Can anyone confirm the same?
    How do you suppose one gets Asus' ear?
    rundell likes this.
  1. Luca92
    3,324
  2. Mark C
    688
