Asus VivoTab Note 8 64GB, looping in recovery, 0XC000000e Help Please!!
Discussion in 'Asus' started by iosub, Oct 5, 2014.
  1. iosub
    iosub Pen Pal - Newbie
    Hi
    I have a Asus VivoTab Note 8 64GB
    yesteday I installed Windows 10 Preview in the MicroSD.
    My idea was to have dualboot of Windows 8 and Windows 10
    After reboot I'm stuck on a "Looping recovery Window"
    The error is "cant load winboot.efi" error 0xc000000e
    Press the windows Key to use another operating system
    I have press the windows key but it does do nothing
    I would like to enter on Bios, I have try Power + Volume+ Power+ Volume- combination..
    Do you know how can I enter Bios?
    any idea how to fix it?
    Thanks!!
    Prasanth likes this.
  2. BenGman
    BenGman Pen Pal - Newbie
    57
    Did you try removing the SD card?
    Or pressing the Windows Key on an external keyboard?
  3. iosub
    yes I did, keeps looping on the same screen.. And Windows Key Does not work.. On the tablet or on the external USB KeyBoard.
    the recovery screen only the power button works to turn of
  4. Prasanth
    Prasanth Pen Pal - Newbie
    I got the same issue. Did you find a fix ?
  5. testplayer
    testplayer Scribbler - Standard Member
    346
    38
    Similar situation here. Maybe I have to call for RMA.
  6. Shogmaster
    4,185
    1,442
    Yep. Same here. I only spent $150 on the thing but I would love to get it working again. Windows 10 Preview killed the poor bugger...
  7. Shogmaster
    4,185
    1,442
    Oh crap, this thread is ancient...
Similar Threads - Asus VivoTab Note
  1. Luca92
    1,655
  2. Mark C
    566
