ASUS Slate HELP! I flashed my Bios-Winflash - failed Ive not rebooted yet!!
Discussion in 'EP121 Slate' started by PCSPC, Sep 9, 2012.
  1. PCSPC
    PCSPC Pen Pal - Newbie
    Hi I wonder if anyone can help..I decided to upgrade from 501 to 704 bios using winflash (win7) it accepted the file EP121F1.704 (4,096kb) and off it went until it completed and left a message -cant remember exact words - but suggested incomplete loading - Should have used (EP121AS.704 - 2,048kb) Anyhow now cannot Flash any other version cos winflash reuses to accept an older file any suggestions - I dont dare turn off the compter and risk a dead machine..
  2. NePheus
    NePheus Pen Pal - Newbie
    51
    Run Winflash with the command promt: "WinFlash.exe /nodate" and try again
  3. CF77
    2,303
    F1 will have error message...another member flashed F1 version and he/she indicated EP121 works after reboot.. He had not reported back since. guess it was ok..
    or you can reflash.
    read the bios threads in this forum as there are lots of info.
  4. NePheus
    51
    I just recommend always to flash the files via BIOS itself. This utility just recognizes the AS file and I had never problems flashing with it. A few days ago I successfully flashed version 704 via BIOS flash utility.
  5. PCSPC
    Thanks Guys your advice works!! "Run Winflash with the command promt: "WinFlash.exe /nodate" and try again" it took a while to figure it out but second time was successful! for anyone else with similar issues heres what i did: Make a winflash shortcut on destop, right click and select properties find the line "C:\Program Files (x86)\ASUS\WinFlash\WinFlash.exe" and change it to "C:\Program Files (x86)\ASUS\WinFlash\WinFlash.exe" /nodate - save and run winflash from shortcut
    Im running 704 now!
  6. NePheus
    51
    There you go, have fun with your slate :) no problem
  7. fxbelloir
    fxbelloir Pen Pal - Newbie
    47
    Based on all your feedback here and there, winflash way is safer than BIOS way.
  8. NePheus
    51
    Maybe you are right ... with winflash you have the possibility to flash a BIOS file again, if there are some troubles. A failed BIOS flash in BIOS itself gets you in trouble. I just flashed modded BIOS 704 with winflash /nodate, everything works fine!
  9. digesterman
    digesterman Pen Pal - Newbie
    Does anyone know of a winflash utility that works with win8 ? The one on the asus site won't load while running 8 on my machine. Thanks
  10. CF77
    2,303
    couple members bricked in win 8 even with winflash..
    revert to win 7 and flash with winflash seems to be less risks.
Similar Threads - ASUS Slate HELP
  1. Gerhard
    2,919
  2. jedah
    2,732
  3. daddyfish
    1,706
