Asus Note 8 installing on SD card??
Discussion in 'Asus' started by rirawin, Jun 14, 2014.
  1. rirawin
    rirawin Scribbler - Standard Member
    214
    18
    About to buy one but before I do, can you install programs like for example Photoshop and Manga Studio on the SD Card, its not perfect but doable?. The 32GB limit is so low.
  2. Kumabjorn
    4,452
    2,632
    You need to make the card a permanent drive using Disk Management, in order to install programs on the SD card. It just takes a few minutes, but remember that the card is the slowest part of the system.
  3. solitaire01
    solitaire01 Pen Pal - Newbie
    65
    That isn't necessary- most programs will install fine on any drive. Some can't without fiddling: onedrive data, Dropbox data, for instance. And it is slower than internal memory. I have several apps installed on my SD card.
  4. Kumabjorn
    4,452
    2,632
    Dropbox won't install on removable media, neither will Office, Chrome or IE.
    Bronsky likes this.
