ASUS ep121 // Samsung Series 7 / Samsung ATIV pro??? (for Comic Illustrator)
Discussion in 'What Tablet PC Should I Buy?' started by SICKHEART, Jan 7, 2013.
    SICKHEART Pen Pal - Newbie
    1. What is your budget?
    1,000 $ (i might pay more if it worth to)
    no (I'm not in USA or UK so i should buy new one cuz it's hard for me to claim if it has any problem)
    anything that suit me most
    bigger is better
    i'm from Thailand but I gotta ask my friend to buy it for me before he came back from USA
    I had bad experience with Samsung Galaxy families (mobile and tablet) but I never try Samsung Notebook or tablet pc
    longer is better but i mostly work indoor.
    drawing, painting
    - I has android smart phone
    - I'm a mac user for 5 years, now i'm a poor Window user but I could try if i have to.
    - I do have ipod
    10. What software and tasks do you intend to run?
    - mostly photoshop and SAI
    - no game
    - much would be better
    2. Will you be using the tablet outdoors?
    - no, indoor only and with plug mostly
    3. Do you require a pen? With or without pressure sensitivity?
    never use Ntrig so i would say WACOM
    Component Specifics
    much is better but i'm ok with external harddisk
    -usb just fine
    I know Samsung spec is higher than ASUS but I have a bad experience with Samsung mobile and tablet before
    I used Samsung Galaxy ace and Samsung note 10.1 and i don't like them at all (sold already)
    now i'm not sure to trust samsung again but....if lots ppl says it worth to, i might courage enough....
    please help me make a decision here!
    Thanks a lot for anyone and sorry for my poor English
  2. Parhelion
    Parhelion Pen Pal - Newbie
    vote for Samsung 7 Slate. A lot of artist use it, a lot of problems already solved.
    - asus a bit outdated
    - Ativ pro has some problems with fullHD resolution (too small GUI) and recent Wacom driver, but that might be fixed later
    All that theoretically, right now i'm bothered what to buy for art just like you
