Asus Eee Note, a peek within....
Discussion in 'Asus (Android)' started by whazzup, Jan 12, 2011.
  1. mp035
    mp035 Underacheiver
    87
    Cheers pb.
    I have eee-note-ized the solitaire app. It has a better colour scheme for the cards on greyscale, and proper location for the cards, with a bottom bar menu.
    It's not perfect, and is surprisingly graphics intensive (svg is not optimal for this type of device), so be patient when restarting a game, or starting a new game. I have not worked out the busy widget yet, so try not to do multiple taps on the buttons if it seems a little slow. Enjoy! It is here.
    @pb, would it be possible to update Full Install to include the new version?
  2. pbarrette
    196
  3. shokley
    shokley Pen Pal - Newbie
    Hi all,
    I'm Vincenzo.
    Do you know if someone tried to boot Ubuntu OS with microSD card?
    And are there some positive results?
    Thanks
  4. pbarrette
    196
    Hi shokley,
    We don't have the kernel source code, so we have no way of compiling a new kernel. Since we can't compile a new kernel, we have no way to boot Ubuntu, or any other OS.
    A good start would be to figure out the machine specific configs required to build an OpenEmbedded kernel for the EeeNote.
    The other problem with booting a different kernel is that we don't fully understand how the current bootloader works, and we don't have the source code to build a new bootloader.
    The EeeNote has a 128MB NAND flash chip soldered to the PCB. The NAND is separated into 5 partitions:
    mtd0 = Bootloader
    mtd1 = EngineKernel
    mtd2 = EngineInitrd
    mtd3 = UserStorage
    mtd4 = BBT
    The internal microSD card has 5 partitions:
    /dev/mss/blk0p1 = SysParams
    /dev/mss/blk0p2 = Initrd
    /dev/mss/blk0p3 = Kernel
    /dev/mss/blk0p5 = Root (ext2)
    /dev/mss/blk0p6 = User Data (ext3)
    We don't currently know the filesystem of "mss/blk0p2" and "mss/blk0p3", so we have no way of replacing the existing kernel or initfs on the internal card.
    I have recently discovered that my ROM CRC calculation isn't quite correct, so we can't stuff a new kernel into a ROM file and let the updater place it for us.
    Basically, I don't currently see a way to build a functional kernel for the device, and I don't see a good way of loading it or booting from it.
    I've been looking at it and have some ideas about messing around with the partitions using a hex editor to replace the kernel, but I'd rather look for a better way of doing that.
    I'd also like to find out how to get the emergency bootloader to restore a ROM from the external SD card. This would make it a lot easier to do kernel replacement testing since I wouldn't be constantly removing the internal SD card, flashing it, then replacing it.
    pb
  5. whazzup
    531
    32
    @pb
    Thanks for the dictionary tip!
    another question:
    I remembered there was talk of the possibility of overclocking the eee note. Have we come any closer to that?
  6. shokley
    Hi Peter,
    thank you for you complete and detailed answer.
    I've another question for you...
    I haven't the possibility to disassemble the eenote and get the internal MicroSD...(I don't want to risk the damage the device).
    I looked at your mods in fullinstall.zip file and I want to install only new apps (solitaire and Phone book and telnet daemon) and new sheet templates...My device language is ITalian and i don't want to repalce it with english language....Is it sufficient to comment lines in "dvt_check" file? And, If the procedure doesn't came out well, How could I restore all without disassembling the device?
    My question could seems to be banal, but I'm not skilled in these procedure.
    Thanks!
  7. mp035
    mp035 Underacheiver
    87
    Hi All,
    I have some more goodies, I've made a terminal app for the eee-note, so now you don't need to telnet in to make adjustments to your eeenote.
    The binary is here.
    This app was based on qtermwidget.
  8. shokley
    Hi,
    it seems interesting
    How to install?
    Thanks
  9. mp035
    mp035 Underacheiver
    87
    Just worked out how to get a larger monospace font, I just updated the terminal app, it's in the same location.
    @shokley: pbarette's dvt_check method is probably the best.
  10. shokley
    Ok, thanks, But, if method fails, how can i restore all without acceeding at internal 4GB memory?
