Assistance/Guide needed: SSD Replacement Toshiba Portege Z10T
Discussion in 'Toshiba' started by tony_1976, Aug 10, 2018.
  1. tony_1976
    tony_1976 Pen Pal - Newbie
    Hi, Sorry I needed help with this issue:
    I purchased Toshiba Portege Z10T-A, 2-in-1 Hybrid Laptop, from recycling center and the SSD was removed. I tried online how to install new SSD but no luck. Any help would be appreciated. Thanks,
  2. DRTigerlilly
    7,476
    672
    301
    I shudder to type this but have you contacted Toshiba support?
    The drive appears to be a 1.8" mSATA (THNSNF256GMCS for the 256gb model)
    I haven't located a teardown guide online, but opening my device was fairly simple, you'll need a guitar pick/rigid cardboard or similar tool to open the plastic clips holding the back of the case in place.
    The teardown for the z20t should be useful as a guide
    pierro78 likes this.
