Artist Solution.
Discussion in 'What Tablet PC Should I Buy?' started by Rockhoward, May 31, 2013.
  1. Rockhoward
    Rockhoward Pen Pal - Newbie
    I'm looking for something to be able to draw on, main priority is running Photoshop CS6 or what will come beyond. Something that can also run Maya or 3D Max current versions also would be great but photoshop/2D is priority.
    1. What is your budget?
    1000-2000$
    Higher if something has everything I need
    Yes
    Convertible, Could be heavy as hell, I'm a big guy weight is not an issue.
    Big screen, big resolution.
    USA
    Nope
    Any, I would be around power sources often.
    Drawing, possibly games to some degree since I tinker in game development
    Windows, which version it ships with isn't that big of a deal.
    Photoshop, Flash, Maya.
    I would like to be able to game but secondary concern, I have a gaming desktop/workstation already.
    Maybe?
    Screen Specifics
    Bigger the Better
    Not really.
    I haven't had a good chance to play around with either but a sensitive pen yes.
    Component Specifics
    500GB, Big is better but if I can hook into a portable HD that is fine too.
    full sized USB would be great.
    Misc
    Something would Gorilla Glass or like technology.
  2. stoneseeker
    3,554
    999
    Biggest screen in a current device, most powerful available in a tablet, wacom penabled, heavy convertible, long battery life, capable of light 3D work...
    Fujitsu T902 qualifies best.
    Also, you could look for a deal on a Fujitsu T901 with Nvidia GPU, but the resolution is lower.
    the other big screen tablets out there are the:
    Modbook Pro
    Taichi 13
    upcoming Toshiba device? (may not have pen support)
    Another contender for power but not screen size or resolution is the Lenovo X230t. Seen some cool 3D work done on that thing as well: Yeti Sculpt by ~sourgasm on deviantART
  3. Shogmaster
    4,093
    1,356
    Taichi 13 is best avoided with it's N-trig pen IMO.
  4. Zero
    490
    There should be Haswell tablets coming out this year.
  5. Zero
    490
    Here is a T902 on sale.
    Fujitsu LifeBook T902 (SPFC-T902-003) 13.3" Tablet PC - Newegg.com
    You might be able to get $100 off by using a certain coupon. I think the only review there was from a troll.
    BTW here is some important info on the T902 from Newegg.
  6. stoneseeker
    3,554
    999
    Agreed. Especially true if your planning on using adobe suite or painter.
    I simply listed the other large devices with active digitizer I was aware of for the sake of completeness in regards to the OP's desire for a large screen tablet. I also don't recommend the modbook, but it's still an option for the OP to compare the T902 against.
Similar Threads - Artist Solution
  1. Kumabjorn
    528
