Are You Having Pro 3 Problems; Did You Change Something?
Discussion in 'Microsoft' started by Steve S, Jul 8, 2014.
Am I Having Pro 3 Problems or Not?
Poll closed Jul 22, 2014.
  1. I changed something and I'm having problems
    1 vote(s)
    14.3%
  2. I changed something but I'm not having problems
    2 vote(s)
    28.6%
  3. I didn't change anything and I'm having problems
    2 vote(s)
    28.6%
  4. I didn't change anything and no problems!
    2 vote(s)
    28.6%
  1. toucan
    toucan Pen Pal - Newbie
    33
    I have had only one problem that I have identified so far (yay).
    When I first received the SP3 I did have WiFi issues on my home network. I use an ASUS AC router (5G). I was getting some ridiculously slow speeds. This past weekend I also had some disconnect issues, but that also showed up on my home computer as well, so doubtful it was something with the SP3.
    I did do the device removal and re-installation step at that point.
    Up until yesterday, when I did do the firmware update and some other installs, that was the only issue I had encountered thus far. I also had almost nothing installed onto the SP3 -- just Dropbox, I think.
    I have not checked anything since yesterday's update to see about WiFi speeds or anything else...
  2. manuelcalavera
    manuelcalavera Scribbler - Standard Member
    402
    21
    You can download the latest driver. It is in the latest firmware pack of Microsoft updates.
  3. ericshmerick
    ericshmerick Scribbler - Standard Member
    108
    Firmware updates will fix all of this. Wifi fix coming next week. No concerns here.
  4. jb82
    jb82 Scribbler - Standard Member
    148
    27
    Had wifi issues with the i5 I ordered when it first came out. Same with the replacement I tried. Would not connect to my wifi router when I first booted up the surface. Would have to manually connect or disconnect then reconnect for it to work. Firmware updates did not fix it.
    Tried a surface i3 1August - same thing happened! I thought oh no not again but then I remember the firware update had yet to be installed. Once the latest firmware update was installed it now works perfectly!
  5. johnnobts
    johnnobts Pen Pal - Newbie
    my i7 256gb pro 3 battery life has been weak. just running with display around 30-40 percent, wifi on, all notifications off, and only using internet explorer and word (newest version), i'm lucky to get 4.5 hours. anybody else have pitiful battery life on their i7? may go back to the i5 version just for the extra 2 hours. performance increase has not been noticeable for me when it comes to gaming at all.
  6. daver
    759
    72
    You're lucky you were even getting 6.5 hours with your i5.
    Even after replacing my i5, I am still only getting 4.5 hours...
  7. RobertFresks
    RobertFresks Pen Pal - Newbie
    SP3 i5/4/128 - works like a charm with different wifi nets. Beefed up the brightness a little on battery and full with adapter. No problem coming out of sleep.
  8. Kumabjorn
    4,315
    2,381
    I have a new and rather odd problem. I decided that my SP3 should graduate to main computer. So I unhoooked Everything from my HP Pavilion g7 and started to hook up my SP3 to all the goodies.
    The first thing I connected was my Anker 9 hub USB 3 port (AC connected) and then I started adding my external drives. Well, that was an interesting experience. Everything connected through the hub (connected to the docking station) took almost two minutes to be recognized and added in File Manager. It took me like ten minute to add Three HDDs, one SSD and one regular USB 64 GB memory. All I can say is wow!
    Don't get me wrong, they are all connected and work fine, but now I'm almost scared to disconnect them because it will take the same amount of time when I reconnect.
  9. gatehouse
    gatehouse Pen Pal - Newbie
    I have one major issue across all surface pro platforms, SP1, SP2, SP3. and they all have same flickering issues to be solved.
    Hello everyone
    I recently encountered the screen flickering at low brightness level with unchecked auto brightness and disabled adaptive contrast , and have installed pwm adjuster software (intel_HD_pwm_adjuster.zip) . However, it did not work out as expected. Has anyone solved this problem ?
    According to the following website's link, the PWM frequency at low brightness (below 55% I suppose) is less than 200 Hz.
    http://www.surfaceforums.net/thread...how-i-got-rid-of-it-buyers-beware.9399/page-2
    The link for intel_HD_pwm_adjuster.zip can be found here :
    http://www.surfaceforums.net/threads/surface-pro-pro-2-eye-strain.8731/
  10. samiapple
    samiapple Pen Pal - Newbie
    Talking zbout the bug, WI-FI will be the NO.1
