Application to sketch on larger pictures or images
Discussion in 'Asus (Android)' started by PF4Tablet, Sep 6, 2011.
  1. PF4Tablet
    PF4Tablet Pen Pal - Newbie
    94
    Hi all
    I am wondering if there is any application that could be used (after ported to eeeNote) to edit large pictures or diagrams saved in a picture format (jpeg, png, tiff)
    I need to make comments on graphs saved as jpg files. The problem that I see with eeeNote is that you can sketch only on a limited size format. Also the sequence "zoom in-sketch-zooom out" is missing (you can use that to work on details.
    Any idea what can be used/ported to eeeNote?
    thanks
    PF
  2. sarah11918
    sarah11918 Pen Pal - Newbie
    98
    I know Xournal has the "zoom in-sketch-zoom out" feature and does exactly what you want on my Nokia N810. I think there's been discussion about whether or not porting it is feasible, but I don't remember what the conclusion was. I'd love to see Xournal, though, and have compatibility between the Eee Note and N810.
  3. TheTwo
    TheTwo Scribbler - Standard Member
    102
    Hi,
    a solution could be to convert the JPG to PDF and annotate this on the eeeNote. After that merge it on the PC with Free PDF Annotation Merger.
    However, I do not know if the zoom capability of the Reader app is enough (400%).
    TheTwo
  4. PF4Tablet
    94
    In my opinion it is a big difference between what you can do in Notes (full use of WACOM capabilities) and what you can do in the PDF reader with annotations.
    I prefer WACOM capabilities
  5. osowiecki
    osowiecki Scribbler - Standard Member
    175
  6. osowiecki
    175
    fixed version :
    easyPaint_fixed.zip
    src :
    easyPaint_src_fixed.zip
    changelog :
    -Program starts with activated pen.
    -removed inactive color palette and second color chooser (for now)
    -gadget dock is now detachable.
  7. blurymind
    blurymind Pen Pal - Newbie
    25
    pressure sensitivity and layers would be awesome!! :)
  8. PF4Tablet
    94
    Cool!
    How do I install this?
  9. osowiecki
    175
    In compiled ".zip" you will find normal dvt_check script.
    copy install folder + dvt_check do SD card.
    reboot device.
    Protip :
    If you wish to uninstall the app you will need to change dvt_check script.
    "Howto" is somewhere on this forum.
    Ill add an uninstaller in the future.
  10. PF4Tablet
    94
    tks
    I figured it out by myself
    Work but seems to have some problems
    The zoom in/out slider at the right bottom side doesn't quite work.... how is it on your eee?
    Anyway I really appreciate your help! Thanks a lot
