Anyone know of a power brick that can output 12v/3A (for Elite X2)?
Discussion in 'Hewlett Packard' started by Ispcolohost, Nov 4, 2016.
  1. Jill F
    Jill F Pen Pal - Newbie
    Did you have success with either the Mos Go unit or the qi-infinity unit. Need an external battery for the HP Elite X2 tablet, as well. Thank you.
  2. jhax01
    jhax01 Pen Pal - Newbie
    40
    I'm afraid not. The MOS Go arrived DOA, I sent it back and didn't try another so I don't know about that one. The Qi-Infinity arrived ok but didn't work.
  3. Jill F
    Thank you for the quick response. I guess you haven't found a solution yet?
  4. jhax01
    40
    I kinda gave up at this point. The MOS Go should work since it explicitly states PD 2.0, but if you do a little research you'll see that they have a lot of quality control problems.
    kvoram likes this.
  5. Ispcolohost
    Ispcolohost Pen Pal - Newbie
    Yep really annoying; ended up buying a stupid car AC inverter so I can run the normal charger while on the go, but obviously does not solve the problem of what to do when traveling other than hauling an obnoxious charger around.
  6. HJK
    588
    72
    Did anyone find a portable power brick that works with the 1012 G1? I want to get one.
    Thanks!
  7. Kilted
    Kilted Pen Pal - Newbie
  8. Kilted
    No inverter need use the auto adapter:
    https://store.hp.com/us/en/pdp/hp-45w-usb-c-auto-adapter?pStoreID=epp
    --Kilted
  9. Steve S
    7,764
    3,248
    <<...which battery do you have? I've been unsuccessful at finding any that put out 12v on a USB-PD / Type C port...>>
    ...Sorry to be late to the party. I can recommend Omnicharge:
    https://www.omnicharge.co/products/omni-20-usb-c/
    Plugged into the USB-C port, this should work for all cases...
  10. Kilted
    Looking at the website. Yes this one should work it has USB-PD.
    I use the Goal Zero Sherpa 100AC.
    --Kilted
