Any tips for a better pressure curve on a tablet PC?
Discussion in 'Artists' started by T-ravisty, Jan 10, 2014.
  1. Azzart
    2,240
    1,560
    There's another tool that, between other things, lets you tweak the pressure curve that works on the surface pro 3: Lazy Nezumi.
    And with more control than Microsoft own app.
    It's not free but if you're a serious artist working with Photoshop you might want to give it a try. You may end up asking yourself how you were able to live before... :D
    https://lazynezumi.com/home
    fishdavis likes this.
  2. Steve S
    7,758
    3,244
    <<...more control than Microsoft own app...>>
    ...As I read the webpage and the FAQs, this tool only works with Wacom technology? So only the Surface Pro (1) and Surface Pro 2?
  3. Azzart
    2,240
    1,560
    Everything works, I just checked again on a surface pro 3 with photoshop cc2014 ;)
  4. Steve S
    7,758
    3,244
    <<...Everything works...>>
    Azzart: Thanks for the follow-up!
    Azzart likes this.
  5. ron2k_1
    992
    171
    This is one funky tool! But besides the squiggly brush, which you can create as a custom brush, what is the practical application?
    I see that pressure curve can be customized for speed, and historical average and all that. But you as a professional make use of it?
    Swiped from my Galaxy Note 4 using Tapatalk
  6. Azzart
    2,240
    1,560
    Lazy Nezumi main purpose has always been being a stroke smoothing tool.
    Think you have to do comic like lineart drawings: in that case it helps a lot since Photoshop has no stroke smoothing options (and I have no good hand even if I'm an illustrator).
    This was the feature I always knew it for.
    I rediscovered it just the other day because I bought a surface pro 3 and, contrary to the cintiq companion, the pen definitely needs some kind of software stabilizer if you need to do slow, deliberate strokes.
    And I discovered it became a great drawing asistant tool nowadays: aside from stroke smoothing, it helps with pressure curve and pressure smoothing, it have that strange distorted lines generator that could be of help in some way and, more importantly, a serie of curve, ellipse an perspective assistant/constraints that are really the icing on the cake.
    To me it values all the few bucks it costs. ;)
  7. lblb
    1,196
    239
  8. thatcomicsguy
    3,240
    2,296
    I tried Lazy Nezumi a year ago, (I don't know if it has been updated or not since), and while I could see how it might be of use, I found the built-in brush stabilization algorithms in nearly every Japanese art program much more satisfying and reliable.
    Paint Tool Sai has the best version, I think. Drawing with that software is dreamy!
    Mangastudio 5 is also quite excellent. -I still use a little program called "Manga Labo", (one of Portal Graphics old offerings). -It's barely supported now, only allows for 32bit usage, but I just pull layouts in from Photoshop for inking, so the file sizes aren't an issue. It's a very solid little inking tool.
    I've not tried the most recent Photoshop, but the version I run is hopeless when it comes to brush stabilization.
    Azzart likes this.
  9. fishdavis
    fishdavis Scribbler - Standard Member
    280
    105
    Thanks for the mention, I picked it up over Christmas and it's been really useful with my Asus Vivotab Note 8. I even use it sometimes on my Cintiq. On the Note 8 (which has less precise lines) it's saved me a lot of cleanup time in PS. totally worth the $
  10. GFXmonkey
    GFXmonkey Pen Pal - Newbie
    80
    22
    Yeah, I've been using Lazy Nezumi this past year and I really like it. I will even use it on occasion in Clip Paint Studio, because it will produce extremely smooth lines. It is a life saver in Photoshop. It is also useful with just a regular Intuos tablet because it helps compensate for the slight wonkiness of drawing where you are not looking.
    stoneseeker and fishdavis like this.
