Android 3.0 on touchsmart
Discussion in 'HP TouchSmart TM2 (Wacom)' started by sarmasboy, Feb 1, 2011.
  1. sarmasboy
    sarmasboy Pen Pal - Newbie
    Hi guys,
    I was just wondering if you've heard of anyone putting Android OS as one of their boot options on HP touchsmart? Considering that the Android 3.0 is specifically designed for tablets, do you think it is possible to put a fully usable version of Honeycomb on HP touchsmart tm2? Maybe you know if anyone is already working on it?
  2. Juke
    Juke Pen Pal - Newbie
    83
  3. sarmasboy
    Well the problem with this is that it's an emulator, not Android actually running as the main operating system. Is it possible at all though?
  4. wakeupneo
    wakeupneo Scribbler - Standard Member
    308
    There is no android for x86 processor (anything more serious than your iphone), other than a lonely project google can find you in no time. The biggest issue is not the fact, that phones and so called tablets are using a whole different architecture of processors, but the fact, that there are no drivers...
  5. Seketh
    Seketh Moderator Moderator
    758
    I think that might change with 3.0.
    There was no reason to run previous versions on x86 tablets. 3.0, however, is designed for tablets. And with the amount of tablets being launched this year, a port is almost inevitable.
    I think we should support any project that comes around to port it to x86, or even start our own. It's not impossible, just difficult.
    Just imagine having all those dedicated tablet apps and games on a Tm2 :drools:
  6. wakeupneo
    308
    The porting to x86 will happen sometime, hopefully with Intel's full support, but it will still take a community to make things work.
  7. Rossman
    Rossman Pen Pal - Newbie
    91
    I have the internet already, I don't need it repackaged into apps (paid or free).
    We (the tech community as a whole) spent a long time porting native apps over to be web apps and now apple and google want to repackage those back up into native apps (that you pay for of course, and they happen to take a cut). If you have a fully functional modern browser available to you there is no reason to need "apps" or an "app store".
    My 2 cents, anyway :)
  8. Thom4s
    Thom4s Scribbler - Standard Member
    157
    Personaly I dont have a need for android 3 on my tm2. The tm2 is a powerfull laptop combined with tablet features. The stront point of the tm2 is the fact that it can run a full desktop os with ease. I dont see the point of android on my tm2.
    I would definately try it, just because i can, but not because i would really run it.
    Maybe as an instant on system which uses very very low battery, that would be something. But still, windows 7 goes out of sleep instantly too so ...
  9. Rossman
    91
    and the TM2 also has that quick-boot O/S as well!
  10. Alec
    Alec Pen Pal - Newbie
