Am I an idiot?
Discussion in 'Asus' started by P8RSON, Nov 17, 2006.
  1. tkinsley
    tkinsley Pen Pal - Newbie
    OK.... someone clue me in here. This is a WACOM pen with the ASUS, right? Is there a driver update that anyone is aware of with the pen driver software? I installed the info pen cd buuuut that seems to have nothing to do with the actual pen driver.
    Also...
    The right click button on the pen is supposed to have some functionality, right? Mine does zilch, nada, zip.
    And, last but CERTAINLY not least... I was under the impression that you could use the top of the pen to erase. Instead, I have to manually select the friggin eraser each time (if I flip the pen over, I get the eraser icon but nothing happens).
    Please feel free to NOT reply to the title question specifically ;)
    Thank you.
  2. Gautam
    Gautam Moderator
    484
    No you are not a idiot, btw -
    1) you shouldn't have to deal with drivers on a new Asus. Did you reformat your machine? It should be ready to go out of the box.
    2) The right click button should work. Try pressing it while tapping. It takes time to get used to gestures. You can customise certain things as well.
    3) On the acer that I have, the erasing feature is REALLY sporadic. If you press a bit harder, it seems to "depress" like a button, and erase a bit. Not a great thing at all. Don't know about the Asus.
  3. deepak
    156
    for the eraser you have to press it gently. if you press the top with your finger you will see it depress slightly. this is a good feature cause it prevents you from accidentally erasing something.
  4. Gautam
    Gautam Moderator
    484
    Wait...if someone stops writing and turns the stylus over, how can the erasing be a 'mistake?'
  5. tkinsley
    OK, maybe I am a semi-idiot.... I never depressed the pen top!
    LOL!
    But I definitely agree w gautam.... if you're flipping it over and making erase gestures, I would think this would be a hard mistake to make if not in the midst of a seizure!
    Still not certain if this is a wacom pen or not. I would like to upgrade the pen asap, as this one is skinny and uncomfortable.... but not sure which pen(s) are best and most comfortable.
    Thanks again...
    Tina
  6. Creole
    Creole Pen Pal - Newbie
    Whilst brainstorming, I routinely flip my pencil around and tap gently on my writing medium... or follow text/lines of thought dragging my eraser around. These are habits I've had for years, and it's unlikely I could unlearn them quickly, not that I even would/could... so the positive control of a button works very well for me.
  7. BornLoser
    BornLoser Pen Pal - Newbie
    54
    tkinsley...
    if you haven't found it yet, here are some different pens Wacom offers that work with tablet PCs. Be careful using any old wacom pen, as some of them are only meant to work with certain tablets and not tablet PCs. You may've known this already, but it's always better to be safe than sorry.
    Link to Wacom Tablet PC pens
  8. caeci11ius
    caeci11ius Moderator Moderator
    167
    In terms of the right click, you have to hold the button and then tap the screen to make a right click (though you can change this behaviour in the control panel, so that all that is required is a button click).
  9. P8RSON
    5,189
    I can thoroughly recommend the Cross Executive pen, not only does it feel much better to hold than the pen from a tablet but it is smoother at writing as well.
  10. Mynd Ara
    Mynd Ara Deus Ex Macchus
    will OEM pens fit in the silo?
